My son accidentally stepped on the side switch on the edge of the spa, turning it on. It is not stuck in the depressed position, so I can switch it on over and over, but it won't allow the pool pump to return to normal circulating operation. I have turned it off at the indoor control panel, I have turned it off at the outdoor panel, I have cycled through all the different operating positions, I have turned everything off and on, I have cleared and reset the automated control sequences, and nothing I do resets the pool operation to "normal" circulation. Any idea how to fully reset/reboot/clear all functions or I have I done it and it's not in the panels at all? Any ideas what else to try or how to troubleshoot?
Thanks!
That was a terrific idea. Unfortunately, when I changed the switch button assignments and turned the pump on, the spa came on anyway. Then I turned on the spa directly from the main panel, and the spa came on again after the required delay. Finally, I turned off the spa from the main panel and after the delay, the spa turned on again, just like before I changed the switch button assignments. Now what?
You need to determine if this a problem with the spa side remote, or the main board. You will need to first disable the spa side remote from your panel in the house.
