bassack42 Posted January 11, 2013 Report Posted January 11, 2013 Want to ask about inground pool heaters. I have a small fiberglass pool. 23' x 14' oval. Like to add a heater. Questions are: Should I go with propane or gas? Electric would be to crazy expensive. What is the cost to run? How much more enjoyment would I get out of the pool? We live in Newport News Va. (Williamsburg/Yorktown area) Quote
LegsOnEarth Posted January 11, 2013 Report Posted January 11, 2013 It will depend entirely on what your rates are locally (for cost) and how quickly you want your pool to heat (for size of heater). Assuming you have a 12k gallon pool (which is what you should have approx based on your size) it would take a 400k BTU heater 2.5 hours to heat your water by 10 degrees. you would then multiply 2.5 hours (usage) by the price of gas for you, which will be measured either in therms (of which you would be using 4per hour) or by cubic foot of gas (which would be 400 cubic feet per hour). This will give you an approximation of you cost. Natural Gas vs Propane doesn't offer a performance difference, just a cost and availability difference. Hope that helps! Quote
Beachbreeze Posted March 13, 2013 Report Posted March 13, 2013 I had a fiberglass pool and wanted to add a heater. The problem I had was there was no main drain, just the skimmer. If that is your case you will find it difficult to heat the pool water that is lower than the skimmer unless your returns are very low. Quote
bassack42 Posted March 14, 2013 Author Report Posted March 14, 2013 Thanks Beachbreeze..My pool does have a main drain. My question still remains. Does a heater give you a fair amount more time to enjoy your pool? And is it worth it?? Thanks to all.....Its mid March, won't be long before I can open the pool! My wife and I put our pool furniture out this past weekend...Its a start! Quote
Pool Clown Posted March 14, 2013 Report Posted March 14, 2013 If your house is on gas (natural), it wouldn't make sense to get a propane heater. Quote
bassack42 Posted March 15, 2013 Author Report Posted March 15, 2013 You are correct...I think I will wait at least 1 more year. Then probably put in a gas heater. Can you get them for under $1500? Guessing we have a 10,000-12,000 gallon system. Quote
