Tiger River Bengal Spa Heating Problem
  • Please log in to reply
5 replies to this topic
#1 brewha69
brewha69
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 20 August 2012 - 05:10 PM
My tiger river bengal spa will not hold it's heat. I've made sure there is no air in the lines. The temperature and water will heat but only to a certain point.(about 90degrees). It will then slowly lose heat over the course of a couple days. It will not heat back up unless I drain it and start over again. It then goes through the same cycle all over again. I've replaced the pump last year and replaced the thermostat the year before. Is it another thermostat problem? I thought maybe I got a bad one. Any suggestions? Please help!
#2 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 22 August 2012 - 05:09 AM
Do you have the serial number?
Owner, Sensible Spa Solutions
#3 brewha69
brewha69
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 22 August 2012 - 09:26 AM
M3F1281
#4 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 22 August 2012 - 02:40 PM
If you have a multi-meter- see if the heater is getting electricity- it's pretty common for heater circuit-board to fail (inside the IQ2020) If you don't have a meter- all you can do is ensure your filters are clean, and the heater breaker is on.
#5 brewha69
brewha69
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 22 August 2012 - 06:40 PM
I cleaned and started it back up and it's now heated to about 102. Problem is, now it will peak at that temp and gradually lose heat over the next few days. I believe the reset button trips on the heater also. Could the thermostat be bad again? I replaced it 2 seasons ago.
#6 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 22 August 2012 - 08:26 PM
If you have a heater reset button, the heater will not begin to heat again until you reset it.
If you have a PDR heater, the PDR doesn't actually require the power to be turned off to reset- it just resets automatically when the heater has cooled.
Do you know which heater you have installed? I believe it came with a PDR heater, but my memory isn't the greatest.
If you suspect a bad thermistor- look at the ready light- is it flashing? It would be unusual for an 04 thermistor to go bad initially, and the chances of the replacement going bad are almost nill. How is the circ pump flow? Have you tried removing the filter?
