harleydude777 Posted August 15, 2012 Report Posted August 15, 2012 looking at putting up a pool but with such a short time left in the swimming season (in Wisc.) I was wondering if we should just wait until spring to do everything....or get it all done now before the snow fly's and it will be set to go in the spring....what are your thoughts? we do have some ground work to do IE: grading/leveling .......or could we do all the ground work....set pool up......but just not put in sand and liner until spring...just not sure what would work best........THANKS Brent Quote
some guy Posted August 25, 2012 Report Posted August 25, 2012 I would hold off doing anything until the spring. If you get everything set up now its just going to be exposed to the elements all winter long. Might as well save yourself the wear on your pool and equipment and wait until the spring. And I would hold off on the groundwork as well. If you do it now and then don't set up your pool your just going to have to go back and redo some of the work in the spring. Quote
