smelansonca Posted July 23, 2012 Report Posted July 23, 2012 24' jacuzzi sand filter and jacuzzi pump well water New Brunswick, Canada The water in my pool has been cloudy for two seasons now. I've replaced the sand this year and make sure all my levels are where they need to be. I've drained a third of the water several times, added many different brands of flocculating agents, shocked the pool over and over. When I vacuum the pool on waste it just shoots the crap back out the eye. I backwash my filter several times weekly and then rinse. Still no further ahead. I have a pantyhose over the Skimmer basket to collect the larger debris and I take care to ensure my pump is free of debris. My floor and walls are not slimy or slippery so it can't be algae, could it? This past weekend we turned the pump off and just let the pool sit after four days the water was clear! I haven't seen past the second step of my ladder since the first year we had the pool. There was, however a large quantity of brown sediment on the bottom of the pool. Since vacuuming on the waste setting justputsthe crap back in the pool, I vacuumed on the backwash setting. Took about an hour, had to switch to rinse and then waste(which still shot crap back into the pool) and then back to backwash just to maintain some suction. Well I was quite pleased with myself, the water wasn't sparkling but at least I could see the bottom of my pool. I put the hose back in her and let it fill with water again, leaving the pump off. Water now at appropriate level, all my chem levels perfect, turn on the pump and an hour later...no bottom of pool again. But at least the water looks blue and not brown. Sigh... Added more flocculating agent, let it run several hours and shut the pump off. I'm now waiting to see what will settle. I've tried that trick several times so far but I always end up back where I started. We took the filter apart last week, removed all the sand, removed the assembly, checked for cracks and loose fittings everywhere, everything seems plumb. I rinsed the sand, picking spruce needles out by hand. Obviously that didn't help either. The first year we had the pool up the water was clear. The last two have not. I am spending all my time trying to clear my pool and none of my time actually enjoying it. I have had my water tested a dozen different times by the local pool company and other than the occasional calcium level a bit too low, everything is perfect. When asking the professionals what I can do to clear my water, they only recommended shocking and adding flocculating agents. Sigh.. anyone have any other suggestions? At my Witt's end. Quote
cruisinfanatic Posted July 24, 2012 Report Posted July 24, 2012 24' jacuzzi sand filter and jacuzzi pump well water New Brunswick, Canada The water in my pool has been cloudy for two seasons now. I've replaced the sand this year and make sure all my levels are where they need to be. I've drained a third of the water several times, added many different brands of flocculating agents, shocked the pool over and over. When I vacuum the pool on waste it just shoots the crap back out the eye. I backwash my filter several times weekly and then rinse. Still no further ahead. I have a pantyhose over the Skimmer basket to collect the larger debris and I take care to ensure my pump is free of debris. My floor and walls are not slimy or slippery so it can't be algae, could it? This past weekend we turned the pump off and just let the pool sit after four days the water was clear! I haven't seen past the second step of my ladder since the first year we had the pool. There was, however a large quantity of brown sediment on the bottom of the pool. Since vacuuming on the waste setting justputsthe crap back in the pool, I vacuumed on the backwash setting. Took about an hour, had to switch to rinse and then waste(which still shot crap back into the pool) and then back to backwash just to maintain some suction. Well I was quite pleased with myself, the water wasn't sparkling but at least I could see the bottom of my pool. I put the hose back in her and let it fill with water again, leaving the pump off. Water now at appropriate level, all my chem levels perfect, turn on the pump and an hour later...no bottom of pool again. But at least the water looks blue and not brown. Sigh... Added more flocculating agent, let it run several hours and shut the pump off. I'm now waiting to see what will settle. I've tried that trick several times so far but I always end up back where I started. We took the filter apart last week, removed all the sand, removed the assembly, checked for cracks and loose fittings everywhere, everything seems plumb. I rinsed the sand, picking spruce needles out by hand. Obviously that didn't help either. The first year we had the pool up the water was clear. The last two have not. I am spending all my time trying to clear my pool and none of my time actually enjoying it. I have had my water tested a dozen different times by the local pool company and other than the occasional calcium level a bit too low, everything is perfect. When asking the professionals what I can do to clear my water, they only recommended shocking and adding flocculating agents. Sigh.. anyone have any other suggestions? At my Witt's end. If waste is coming back out the eye, you're filter is broken somehow or you're not using it right Quote
Pool Clown Posted November 5, 2012 Report Posted November 5, 2012 Take a picture of your backwash valve in the filter position, and post it. When the valve is in "waste", you shouldn't be getting any water at all through the return (eye). Also, how long are you running the filter each day? Quote
LegsOnEarth Posted November 6, 2012 Report Posted November 6, 2012 Also, saying that your chemistry is "perfect" doesn't mean anything. You should definately post a full set of water test results so we can get an idae of just how your water "looks." What is actually "perfect" and what the pool store claims as "perfect" are very different things. If you have stuff coming back into your pool it sounds like a broken lateral or a bad spider gasket... You said the filter internals had no signs of damage? The "fingers" at the base of the filter weren't cracked? That would make me think you have issues with your vavle. Quote
Poolspotpro Posted February 18, 2013 Report Posted February 18, 2013 I could be wrong but it sounds like a chemistry issue moreso than the filter. To make sure, superchorinate by adding 10 gallons of liquid chlorine to the pool. I know thats a lot of chemical but you've gotta have enough shock effect to burn out everything including maybe too much added algacides. Maintain only one tablet and adjust the Ph after a day or two. Run the filter 12 hrs per day and each day vacuum the dead debris from the bottom of the pool out to waste and into the yard. Vacuum just before the pump runs so you can make sure and get all that dead stuff that settled to the bottom. If in a few days your pool looks perfectly clear(which I think it will), then that'll tell you that it was a chemistry balance issue. Quote
