Thanks for any and all help
#1
Posted 11 July 2012 - 02:57 PM
#2
Posted 12 July 2012 - 08:01 PM
If your heater's blower is not coming on:
Check connection/wiring to the blower(rats).
Check wires F1 and F2 from the ign box to the board for connection and, well, evidence of rats . While youre in the ign box, check the fuse, Rat eating the right wire could cause a short that would blow that fuse.
Check that your membrane(touch pad) is still intact and is not de-laminating. Iv'e seen this turn off the heater, then stop responding to touches, effectively locking out the human.
Check the automation heater switch wire(if applicable) for rat-age.
Just so i got it right, you apply power to the heater, heater boots up(silent) and then it goes dark?
Factory Warranty/Service for:
#3
Posted 13 July 2012 - 04:08 AM
I checked it this morning again and it does say AFI near the light- The blower motor looks like the mice used it for a toilet and it sparked when I tried to disconnect the white wire connection leading to it. My buddy tested it with a volt meter and said there is power going to the motor so he recommended replacing the entire blower system. They are expensive so I want to be sure that is the problem.
I'll check the fuses again but I am pretty sure they are ok. The motor itself does still spin so maybe its just a part of the motor and not the entire thing that needs to be replaced?
#4
Posted 13 July 2012 - 01:22 PM
Correct.
Problem is i do not know of any motor fix for this that doesn't involve replacing the whole thing. Unless you have a local motor guy that is willing to take it on maybe?
#5
Posted 17 July 2012 - 01:38 PM
#6
Posted 17 July 2012 - 03:19 PM
You are correct, they do that. You can try throttle-ing the gas valve a little(the one on the outside of the heater) to get the whistle to stop, but you didn't hear that from me.Its making a whistling sound now but ive heard that the older blowers will do that.
#7
Posted 27 July 2012 - 08:10 AM
#8
Posted 27 July 2012 - 04:14 PM
Also tagged with one or more of these keywords: heater
Hot Tubs & Spas →
Portable Hot Tubs & Spas →
Hot Spring Prodigy Heater Not Working, Now Pump Not Working EitherStarted by tonyhubb, 18 May 2013 |
Swimming Pools →
Inground Swimming Pools →
Jandy Lx250 Heater Not HeatingStarted by JNC, 08 May 2013 |
Hot Tubs & Spas →
Circuit Breaker TripsStarted by Tubblin, 05 Apr 2013 |
Swimming Pools →
HeatersStarted by bassack42, 11 Jan 2013 |
Hot Tubs & Spas →
Heater Going BadStarted by Zapman, 25 Dec 2012 |
