Hair Line Crack Almost A Foot On Floor Shallow
Started by Delgado, Jun 13 2012 07:39 PM
1 reply to this topic
#1
Posted 13 June 2012 - 07:39 PM
So just noticed a hair line crack on the bottom of the pool in the shallow end of the pool , should I be worried ,
or is there a way to fix it whith out emptying the water , or is there a way to see if the water is leaking through there ,
#2
Posted 26 June 2012 - 06:59 PM
I have some cracks in my pool as well. Plaster pool 25+ years old. I asked a proffesional that was out quoting a new pump for me and he said as long as the pool is not losing water its probably just cosmetic. To test for a leak he suggested I do the bucket test. Google pool leak bucket test. He also said that cracks can be repaired without emptying the pool but was against me doing it unless there really was a leak because it wasnt cheap he said.
If you have or think you have a leak, you can get dye that you drop near the crack and if there is a leak you will see the flow toward the crack. I guess they sell it in the pool stores or online.
