damoore Posted January 12, 2012 Report Posted January 12, 2012 pump is leaking at the bottom of the wet end. just doing some ground work for the home owner. pump works great other than the leak. any info would be appreciated. thanks Quote
Spa God Posted March 3, 2012 Report Posted March 3, 2012 It is likely not leaking from the bottom of the pump, when the seals between the motor shaft and the wet end start leaking it runs down the back of the pump and drips off the bottom of the pump making it look like it is leaking there... likely you need to replace the pump seals. Quote
