Z115/315 Jacuzzi Echo-No Power To Topside Control - Portable Hot Tubs & Spas - Pool and Spa Forum
(March 25, 2015) POOLSPAFORUM.COM IS INSTALLING A MAJOR SOFTWARE UPGRADE.
EXCITING NEW FEATURES ARE JUST AROUND THE CORNER.
  • Please log in to reply
No replies to this topic
#1 hurook
hurook
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 07 June 2011 - 06:03 AM
I have an issue with a Z115/Z315 echo spa. I had it up and running all last year just fine until winter came.
Then when I went out to check it one week, the spa had shut down and there was a thin layer of ice on top,
about 1/4" or so. The breaker had tripped. I tried restarting to see if I could "save" it rather than unfreezing
and draining. The pump motor kicked in for a few seconds and then quit. So I used space heaters to completely thaw
and then drain the spa.
This spring, I have no power power to the topside control. I did isolate the pump motor to make sure I didn't burn
it out and it works. There is power to the board as I was using a multimeter to check a few of the relays. I haven't
replaced the fuses yet, but will do so just to rule it out.
Just looking for suggestions as to where I should start troubleshooting from someone with more experience.
Any help or suggestions is much appreciated!
website security
