Tub Is Actually Too Hot!
  • Please log in to reply
6 replies to this topic
#1 Scrufnut
Scrufnut
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 17 April 2011 - 05:47 PM
I own a 2002 Tiger River "Bengal". Today we are experiencing a condition where the water temperature has actually overshot the "set" temperature by 3+ degrees. Its been two months since changing the water so its not like its heating it from cold water. Normally keep the tub at 103 in the winter. Since the temperature indicator light was out, I starting stepping the temp setting up until the light came on; it did so at 104 (being the low end). The light stays on for 5 steps of the temp setting, so that meant the water was at ~106 (being the mid-point).
I've read plenty of articles where there was no heat,nothing yet for too much heat. Anyone have any ideas?
#2 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 18 April 2011 - 05:30 AM
Try putting it in "summer mode."
It's just excess heat generated from the circ pump.
Owner, Sensible Spa Solutions
#3 Jake the dog man
Jake the dog man
    Spa Savant
  • Members
  • PipPipPip
  • 131 posts
  • Gender:Male
Posted 18 April 2011 - 01:17 PM
I have found all the tubs I have owned, all Hot Springs, heat a few degrees hotter then the setting. Try lowering the setting to 100 and see if the water is actually 103/104. My current Tiger River seems to always run 2/3 degrees hotter. I don't think it is a big deal.
#4 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 19 April 2011 - 03:16 PM
Jake, while some Hot Springs might run hot, that's not this issue. By using the "ready light" indicator to asses the current temp, he ruled out a thermistor out of calibration. He could turn it down to 80, and the spa wouldn't cool. I uses this line often in S Florida, as this issue is prevalent in this tropical climate with several well insulated models... "The spa doesn't come with an air conditioner."
The ready light uses the same thermistor to energize the heater to tell you the temp of the spa. If it's not lighting until several degrees above the set temp- it wasn't the heater that got it so hot.
In fact, this is the very reason for the existence of "summer mode" on these spas. Left unattended, in warmer climates, the spa can reach upwards of 110F, without the heater ever coming on.
If his ready light was staying lit, and was actually warmer than the set temp as well, then turning it down would be a great solution. But the fact that the thermistors are working is a pretty good indicator that turning it down probably won't help, unless he vents it also.
#5 Jake the dog man
Jake the dog man
    Spa Savant
  • Members
  • PipPipPip
  • 131 posts
  • Gender:Male
Posted 19 April 2011 - 07:15 PM
Ok, I see that now. I also use the summer mode, but haven't yet this year.
Good Luck!
#6 Scrufnut
Scrufnut
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 20 April 2011 - 02:33 PM
PreservedSwine,
Thanks for your response. I live in VA and we haven't gotten to the point where day/night temps are affecting the tub temperatures. It's usually in July/August when we open the tub up at night to cool down.
Actually it is the heater that's getting it hot, with the thermostat set to 103, the water temp at 106, heated water was still coming from the floor port.
Looking at all the other responses, I have had this tub for 9 years and my thermostat has been very accurate, plus I measure it against an electronnic thermometer.
I was thinking that either the thermister or the tub's control board has a problem. I am out of town this week so have shut off power to the heater so as not to cause further damage. When I return, I will completely shut down power in hopes of maybe resetting the control board if its hung up in anyway.
Any other thoughts?
#7 PreservedSwine
PreservedSwine
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,408 posts
  • Gender:Male
Posted 21 April 2011 - 03:55 AM
PreservedSwine,
Any other thoughts?
Scenario: The actual spa water temp was 106. The "ready" lights up at 104 (and stays lit UE1-UE4), but was not illuminated while at the set temp of 103, or lower?
Do I understand you correctly?
It sounds as though the thermistor is working- it's accurately observing the temp of the water as roughly 106, and the electronic thermostat is properly calibrated to interpret the thermistor readings as roughly 106.
If you had a bad thermistor, (one that say... interpreted 103 as 106), then your "ready light" would be happily glowing while set at 103, even though the actual temp was 106. Yours does not. It still interprets 106 as... 106.
I've seen a few "stuck" heater relays, but they don't run a "little" warm. They heat until they trip the high limit. Are you 100% certain the heater is energized, while the spa is set at a temp *lower* than the thermostat registers? That's a potentially dangerous problem.
