Trouble Shooting Nature Soft/gold Line Controls
  • Please log in to reply
3 replies to this topic
#1 elevatorman
elevatorman
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 12 March 2011 - 10:13 AM
We recently purchased a home with a built in pool that has Salt system on it. It has worked excellent except for having to replace the flow switch last summer. It is a Nature Soft/GoldLine Control system. Recemtly it has develpoed a problem. No power LED when pump is running. I verified that it does have power (220v) Possible burnt out LED. The flow LED will go out after start up and the Generate LED comes on for @ 5 seconds then goes out. Switching to Super Chlorinate does nothing (No LED). The system is not making chlorine. Any help with his would be great. Part numbers for boards are Power Board #= 132603G /Display Board #= 132604.
#2 pbartholomew
pbartholomew
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 11 April 2011 - 04:00 PM
I am getting the same exact symptoms from my Goldline Aqua-Rite. Have you fixed your problem?
What did it take?
I'm beggining to suspect the PCB Board is shot. There is a dark black spot at the solder of the round component in the top right corner of the circuit board (SL32-2R025 25A 2Ohm Current Limiter), it is next to the control lead connectors.
But I think the original culprit was a shorted wire from the flow control sensor.
Any help would be greatly appreciated.
Thanks.
#3 Spudman80
Spudman80
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 07 July 2012 - 01:17 PM
I have just encountered the exact scenario on my goldline control PCB 132603: black at the SL32-2R025 25A 2 ohm limiter. I am certain it was due to a short in the flow switch/indicator line coming into the board (the telephone line from switch to control panel had a shirt in connector).
So question is, can you buy the limiter? If so, Where?
#4 Spudman80
Spudman80
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 07 July 2012 - 01:34 PM
Found out the part can be bought through Newark or Digikey. Placed the order and will see if it fixes the issue.
