How To Override 104 Limit
  • Please log in to reply
10 replies to this topic
#1 sealginCO
sealginCO
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 17 February 2011 - 04:47 PM
I have read a lot of the dialog on this topic. I too want to increase my spa temp by a few degrees sometimes.
I also am aware of all the nanny's who want to lecture us about how the federal temperature police will get us. That is my secondary motivator - to do it just because the nanny's dont like it.
Anyway... the resistors in sensor circuit approach seemed like a rats nest to me. Defeating my Balboa controllers seemed pretty impossible. So here is my brute-force but quite simple method. Works great!
Buy:
--15 minute wall timer (like from homedepot)
--240v/12vac relay
Now:
--Run line voltage from the controller's line-in posts to the relay
--Run line voltage from the relay to the spa heater terminals.
--Supply the relay with 12vac from the Controller's transformer.
--Switch the relay with the 15min timer.
Operation:
--When I set the timer, the heater will turn on regardless of temperature. I do this about 10 or 15 min before I get in the spa. The spa heats at about 5 degress per hour so its easy to set the timer for two or three degrees of increase over the starting temperature. This takes the temp from 104 to about 106 - which is what I want.
-- My spa has an always-on circ pump so starting the heater is not a problem. If your spa runs on a filter cycle then you will have to ensure that the pump is running before you turn on the heater - else it will instantly burn up. You may think of your own creative way to ensure the pump is running.
-- no resistors. no controller changes. no bogus temperature displays. Hooking this up is easy if you are smarter than a 5th grader and not a nanny.
#2 Dr. Spa
Dr. Spa
    Advanced Moderator
  • Moderators
  • PipPipPipPipPip
  • 2,430 posts
  • Gender:Male
Posted 17 February 2011 - 05:51 PM
Well that beats wiring in a 12 cent resistor
What the heck do I know, I only started in this industry in 1981, and retired from it after 33 years.
From service tech to co-owner of Roberts Hot Tubs, manufacturer of traditional wooden hot tubs & spa covers.
If you can't sell it on ebay, it may not even qualify as landfill.
#3 drylandfarmer
drylandfarmer
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 17 February 2011 - 06:32 PM
Some controllers allow you to do it by pressing a couple of buttons. 106 is veeerrry niiice. (Borat voice)
#4 Pathfinder
Pathfinder
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,271 posts
Posted 17 February 2011 - 07:29 PM
Not after 2006, before it was no problem
Canadian Vinyl Liner Installer Extraordinaire
#5 Dan.The.Spa.Man
Dan.The.Spa.Man
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 700 posts
Posted 17 February 2011 - 08:46 PM
I have some controllers for CalderaSpas that will go to 108 degrees if any one is interested...LMK
I have a few extra HotSpring heater relay boards for tubs from 2001-2008 if anyone is looking for one cheap. Part #77119
#6 Hillbilly Hot Tub
Hillbilly Hot Tub
    Certified Tech
  • Moderators
  • PipPipPipPipPip
  • 1,282 posts
  • Gender:Female
Posted 18 February 2011 - 08:40 AM
Doesnt your system shut down since it should sense an overheat. Circ pumps shut off when 2 degrees over the set temp, entire spa shuts off when it reaches 107-108, You would have to be careful since overriding these protections could toast the control system and or other components
Moderator
Spa and Sauna Sales and Service center
Clearwater and Great Lakes Spas
Helo and Almost Heaven Saunas
Spa Search certified dealer
APSP Member
CPO
#7 PoolSpaGuy30
PoolSpaGuy30
    Spa Savant
  • Members
  • PipPipPip
  • 248 posts
  • Gender:Male
Posted 18 February 2011 - 09:18 AM
many spas straight from the factory can override to 106 but 108 is nuts...waay to hot for my liking
Hot Spring Spa Sales
10+ years in swimming pool remodeling and servicing
"you get what you pay for"
"if it seems to good to be true, it is"
<inappropriate comment deleted>
-my favs
#8 Dr. Spa
Dr. Spa
    Advanced Moderator
  • Moderators
  • PipPipPipPipPip
  • 2,430 posts
  • Gender:Male
Posted 18 February 2011 - 09:24 AM
FYI. All of this has nothing to do with nanny's or the federal temperature police. It IS all about liability and the litigious populating of this country.
On Dec 31, 1979, the Consumer Products Safety Commission (CSPC) released advisory #79-071, which warned of heat strokes caused by 106 F water. This advisory recommended 104F as the maximum temperature for a spa. Underwriters Laboratory (UL) adopted this advisory and lists it in their controlling document for home spas, #UL 1563 (Electric Spas, Equipment Assemblies, and Associated Equipment.
With all of that, if someone, ANYONE, were to get injured in a spa, and could successfully argue that the injury was caused by the temperature of the water being OVER 104 degrees and that the spa manufacturer* designed the spa to operate this way, just about any court in this land would rule against the spa manufacturer. "You knew there was a possibility of water hotter than 104 to cause injuries, therefore you're liable".
This could EASILY be a 6 figure, if not 7 figure judgment. Of course, everyone has insurance, and that would pay the judgment...maybe. Now the insurance companies are saying, if you want us to insure you, your spa can't go above 104.
If you want to blame someone, look to the people that refuse to take responsibility for their own actions and will sue anyone for anything at any time...just to make a buck (I won't even begin to start in on attorneys, that perpetuate this type of thing).
*It's very easy to alter a spa to increase it's maximum temperature. But, if I tell you how to accomplish a higher than 104 temperature, I then also have the same liability. Don't even start in with, "I wont hold you responsible", or, "I'll sign a release". Over and over, these things have been shown to not be worth the parer they're written on in court.
#9 drylandfarmer
drylandfarmer
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 18 February 2011 - 01:57 PM
You can still overide the 104 max temp on some hot tubs built after 2006, mine is a 2010 model and I have it set for 106 degrees, was easy to do, kinda just stumbled on it.
#10 Dnepr Dave
Dnepr Dave
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 529 posts
  • Gender:Male
Posted 18 February 2011 - 03:09 PM
My 2005 Caldera has two OT (Over Temperature) settings above 104 F. So I can just got to OT2 and I have 106F. but that is too hot for me. I keep it set at 103F.
Dave
2005 Caldera Kauai
#11 texasradio
texasradio
    Junior Member
  • Members
  • PipPip
  • 26 posts
  • Gender:Male
Posted 19 February 2011 - 10:34 AM
With Hot Spring, there is evidently some trick to override the 104 setpoint on the new models, because this is what a local dealer told me. But only if you buy the new spa do you get the info. Since I have a 2006, it's not an issue because these models have higher setpoints that are "coded" ut1, ut2, ut3, and ut4. How these codes would shield them from liability issues, that is a dang good question.
Anyways, my spa appears to have a 2-4 degree variation between setpoint and actual. Then again, I don't have a whole lot of faith in the accuracy of the floating thermometer that came with the tub. But if the tub temperature is out of whack, then it is likely Hot Spring has a way to adjust or compensate for the difference. My guess is that therein lies the "trick" to temperature modifications.
2006 Hot Spring Jetsetter w/220v
