Pool Wont Stay Primed
  • Please log in to reply
4 replies to this topic
#1 pooldummyaz
pooldummyaz
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 05 February 2011 - 11:47 AM
I have a hayward pump that doesn't want to stay primed on the pool suction side. It is plumbed with a jandy valve to select between spa suction and pool suction. On the pool side it is then separated again into skimmer and cleaner pipes with old metal gate valves. When I turn the jandy to spa only suction the pump primes perfectly. Once I turn it over to pool only pump won't prime..
I am guessing these gate valves are just worn out and allowing air to enter the system. One valve is actually stuck and doesn't move at all. Should I just re plumb with 1 1/2 pvc ball valve?
I have checked everything else. Lines are clear and impeller and o-rings are all good and in place.
Thanks
#2 Zed
Zed
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 05 February 2011 - 07:44 PM
Thanks
Do you have a pool cleaner? If yes check that there are no holes in the hoses. Check for suction leaks on the pool side piping. Sounds like your sucking air from somewhere. Regardless, I'd change out those gate valves.
#3 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,286 posts
  • Gender:Male
Posted 05 February 2011 - 07:50 PM
When you replace the gate valves I would not replace them with ball valves. Spend a bit more and replace them with 2 way Jandy type valves (never lube type). It is worth the extra money in the long run.
Board Moderator
#4 AFiremanFirst
AFiremanFirst
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 384 posts
Posted 07 February 2011 - 02:46 PM
I agree with waterbear! ball valves are inexpensive incomparison to jandy valves, but they are completely rebuildable, and in the long run you'll be more pleased. Often times you can turn the system on, get it primed off the spa, then switch your valve open and shut the system down. With a good ear you'll find your leak.
#5 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,286 posts
  • Gender:Male
Posted 07 February 2011 - 03:42 PM
I believe you mean the jandy type valves are rebuildable and better in the long run. Your post did not make that clear.
Board Moderator
