Homade Cartridge Filter Cleaning Solution?
  • Please log in to reply
11 replies to this topic
#1 Seahunt
Seahunt
    Spa Savant
  • Members
  • PipPipPip
  • 114 posts
Posted 04 January 2011 - 07:47 AM
I understand you should soak the cartridge filters in a cleaning solution to remove oils, lotions, etc. The cartridge cleaning solutions sold in my area are pretty expensive and to get enough to do my filters would cost quite a bit of money. Is there a generic or homemade solution that does the same thing as the pool store cartridge cleaners? Thanks!
#2 Dr. Spa
Dr. Spa
    Advanced Moderator
  • Moderators
  • PipPipPipPipPip
  • 2,339 posts
  • Gender:Male
Posted 04 January 2011 - 08:46 AM
TSP
What the heck do I know, I only started in this industry in 1981, and retired from it after 33 years.
From service tech to co-owner of Roberts Hot Tubs, manufacturer of traditional wooden hot tubs & spa covers.
If you can't sell it on ebay, it may not even qualify as landfill.
#3 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,286 posts
  • Gender:Male
Posted 04 January 2011 - 10:15 AM
One cup of REAL TSP-trisodium phosphate (not TSP substitute that is often the only thing available in many localities) or 1 cup of automatic dishwasher detergent powder to every 5 gallons of water. Soak cart overnight in solution (cart should be completely submerged) and rinse well with garden hose using small bore nozzle (the short brass ones that cost about $2-3 work best).
Board Moderator
#4 Seahunt
Seahunt
    Spa Savant
  • Members
  • PipPipPip
  • 114 posts
Posted 05 January 2011 - 04:40 AM
Awesome! Thanks!
#5 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,286 posts
  • Gender:Male
Posted 05 January 2011 - 09:46 AM
I might add that this will not work if you are using a biguanide based system like Baquaspa, SoftSoak, Revacil, etc. If you are using bigaunide you MUST use the special filter cleaner that is sold along with these systems or you will ruin the filter.
Board Moderator
#6 Seahunt
Seahunt
    Spa Savant
  • Members
  • PipPipPip
  • 114 posts
Posted 05 January 2011 - 01:09 PM
Nope, just plain old chlorine (trichlor and liquid chlorine). Thanks again!
#7 allin1poolcare
allin1poolcare
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 12 January 2011 - 07:38 PM
after the TSP, soak the element in acid solution (1 to10) to remove any calcium or other build up. Soak it for like 5 hours and then hose it down. Just make sure you do the TSP first.
#8 Dr. Spa
Dr. Spa
    Advanced Moderator
  • Moderators
  • PipPipPipPipPip
  • 2,339 posts
  • Gender:Male
Posted 12 January 2011 - 07:54 PM
NO! Do NOT soak it in acid UNLESS there IS a calcium build up...and then, ONLY soak it till any bubbling stops (once the bubbling stops, the calcium is destroyed). Soaking it in acid WILL deteriorate and shorten the life of the filter, but is necessary and/or advisable to remove calcium.
#9 waterbear
waterbear
    Village Idiot ;)
  • Moderators
  • PipPipPipPipPip
  • 3,286 posts
  • Gender:Male
Posted 12 January 2011 - 08:53 PM
Dr. Spa is right on the money! A good way to test to see if you need to acid wash is to mix up a bit of dilute acid :(10 to 1 dilution or even a 20 to 1 dilution) and put a few drops on the filter. If it fizzes then soak it until the fizzing stops (usually about 15 minutes). If not you do not need to acid wash.
Board Moderator
#10 macdodd
macdodd
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 19 August 2012 - 09:10 AM
Hey waterboy,,,,can I make up a solution of the TSP as you said and put it in a spray bottle? We don't use any suntan oils or such. I have a salt pool and clean the filter every week. Thanks for your time.
#11 PoolGuyNJ
PoolGuyNJ
    Owner PoolGuyNJ LLC
  • Members
  • PipPipPipPipPip
  • 780 posts
  • Gender:Male
Posted 21 August 2012 - 02:02 AM
A spray won't be enough to degrease. I use a clean garbage can and a about a half a box of cheap powdered dishwasher detergent. This solution also is useful for soaking DE panels. I generally use an 8 hour schedule as a minimum
The body excretes skin oil so even if you don't use lotions for tanning or bug repellents, there is still going to be oils that are absorbed by the pleated material. Bather load plays into this too. What others use may be unknown.
Cleaning weekly will actually shorten a cartridge's life and keep it from filtering as well as it can. For a pool filter, this can also cause other parts such as the middle O-ring and clamp to wear prematurely. If it's really needed weekly due to the environment, the cartridge is undersized. For many spas, the threads that hold the element in place can wear prematurely and the plastic top, bottom, and any bands around the middle of the cartridge meant to separate the pleats.
Unless you have hard water, acid baths aren't needed normally. A 4 -1 water acid solution for a short spell will dissolve any leftover calcium. If it needs to be done, do it after degreasing or that becomes a non-removable goo and the cartridge is toast. If it is needed more than quarterly, your CSI is too positive.
Scott
Owner OF PoolGuyNJ LLC
I have fixed nearly every residential pool problem so far. If I can't do it, I know who to call.
#12 sdt442
sdt442
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 08 October 2014 - 02:09 PM
why can't you use a cup of bleach in a 5 gallon bucket, what would that do?
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
