Sundance Chelsee Won't Start
  • Please log in to reply
4 replies to this topic
#1 teamblair
teamblair
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 23 October 2010 - 10:37 AM
We have a Sundance Chelsee series 780 spa and the power has turned off. When the breaker is reset an error code 356 comes up. We just noticed that there is water in the stero on the top of the spa. Could this be what is causing the spa to turn it's self off? Or is there something with the mother board that needs to be replaced? All the service departments are closed today and we really wanted to use the spa this weekend. Any help you can give would be greatly appreciated.
#2 Spa_Guru
Spa_Guru
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 958 posts
  • Gender:Male
Posted 23 October 2010 - 01:20 PM
Water on or in the stereo won't cause it, I am not familiar with code 356, does it come on and stay on?
Error codes by manufacturer;
http://www.rhtubs.co...Error-Codes.htm
"Men nearly always believe what they wish to be true"
Julius Caesar
"Having the best price, the best service, and the best quality all at once is impossible"
Zig Ziglar
#3 teamblair
teamblair
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 23 October 2010 - 03:20 PM
The GFI breaker keeps tripping and no power at spa. We disconnected power at spa control box and GFI breaker stays on, but if we hook power back up to spa breaker trips. spa worked great last weekend, we use it weekly.
#4 Mikey_in_NY
Mikey_in_NY
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 298 posts
Posted 23 October 2010 - 04:16 PM
Dont know if this helps. Sundance, but different model, same error code...
http://www.poolspafo...?showtopic=9625
#5 n1oty
n1oty
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 473 posts
Posted 24 October 2010 - 03:27 PM
You have a ground fault somewhere in the tub. Usually, it is a heater or ozonator (if equipped). Do not keep putting power to this particular board or you will damage it and dramatically escalate your repair costs. The proper method of ground fault testing is to isolate each load and ground fault test with a megohmmeter. The 356 is NOT an error code.
John
