nomansland Posted September 2, 2010 Report Posted September 2, 2010 I was given a Sundance spa with a Sentry 800 controller. The unit does not work and I would like to find the schematic for the controller board. I have found a pdf of the controller manual on the sundance site. http://www.sundancespas.com/Communications/InstructionManuals/91_92800Man.pdf It has a diagram on how to hook up the controller but no schematic of the controller PCB. Quote
ed3553 Posted September 2, 2010 Report Posted September 2, 2010 I was given a Sundance spa with a Sentry 800 controller. The unit does not work and I would like to find the schematic for the controller board. I have found a pdf of the controller manual on the sundance site. http://www.sundancespas.com/Communications/InstructionManuals/91_92800Man.pdf It has a diagram on how to hook up the controller but no schematic of the controller PCB. The diagram contained in your pdf is the only diagram that is provided. If your looking for a diagram of the circuit board you will have to contact Sundance directly and see if they can provide that. I have been doing this 18 years and the manufactures do not supply a diagram for PCB circuits. Quote
