gcally Posted August 9, 2010 Report Posted August 9, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg Quote
Daniel Erlandson Posted August 10, 2010 Report Posted August 10, 2010 hey... just completed the exact same thing on a D1 today. It has been a long haul in fixing the leak. I used the "big gap" expandable foam from Home Depot...I think it is Great Stuff. Seemed to work well...a total of 10 cans! Just go slow with it and let it cure for the 1 hour before you pump the next can on top of the expanded foam. The foam does generate some heat and expands in all directions so be careful as you pump it in around any piping. Make sure it doesn't push any of the piping out of place. I did find it helpful to use some boards to support the foam in places...my tub is on its side and I used the boards to keep the foam from sagging too much dan Quote
masanori Posted August 10, 2010 Report Posted August 10, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg Greg, I would suggest 2lb cuft foam.Where are you located? I develop the insulation that is used on most hot tubs. Quote
Roger Posted August 10, 2010 Report Posted August 10, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 Quote
gcally Posted August 10, 2010 Author Report Posted August 10, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 Wow that is out of my price range! Is there any real difference in heat insulation between the Home Depot Great stuff and the stuff you use? Quote
gcally Posted August 10, 2010 Author Report Posted August 10, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 I am in Beaver Falls PA near Pittsburgh. How much is this stuff and where can I find it? Quote
masanori Posted August 10, 2010 Report Posted August 10, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 Wow that is out of my price range! Is there any real difference in heat insulation between the Home Depot Great stuff and the stuff you use? Its expensive because its a class 1 foam. That means its fire rated.Fire rating is determined by the amount the foam burns and smoke Quote
hottubdan Posted August 11, 2010 Report Posted August 11, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 I am in Beaver Falls PA near Pittsburgh. How much is this stuff and where can I find it? Do you have a Tap Plastics? That is the stuff we would use also. Quote
Roger Posted August 11, 2010 Report Posted August 11, 2010 I had to fix a couple of freeze breaks in a tiger river spa that I bought used. I had to dig out a fairly large amount of foam and I am finally at the stage of reforming the underside of the tub. My question is what type of foam should I use? Great stuff sells a couple of different kinds... Low window expendable foam, normal expendable foam, and High expendable foam. Is there some kind of special stuff I should use? Thanks Greg I use this stuff http://www.jrproductsinc.com/shop/pc/viewPrd.asp?idcategory=11&idproduct=56 I am in Beaver Falls PA near Pittsburgh. How much is this stuff and where can I find it? Grainger also has 2 part spray foam in sizes ranging from 80 bucks to 400 Quote
Dnepr Dave Posted August 12, 2010 Report Posted August 12, 2010 I'd just use the canned stuff from Home Depot, don't over think this. Dave Quote
Rover1 Posted August 12, 2010 Report Posted August 12, 2010 We also had to repair leaks on a Tiger River spa. Before I used the Great Foam I wrapped the joints in black plastic to make it easier to find them if I needed to dig it out again. Just let the foam expand completely before adding to it, otherwise you will be shaving off a lot of excess. Quote
dugathome Posted October 13, 2014 Report Posted October 13, 2014 Quick follow-up. I am in the middle of a similar project on my Tiger River Bengal tub. My question is when I removed the foam in the corner of the tub near the end of the "pump duct hose" (the large diameter black flexible hose), it seemed to have a softer consistency. Was I imagining it? Should I use something else in that area? Quote
mrwrick Posted November 6, 2014 Report Posted November 6, 2014 My Hot Spring ZClassic underside insulation blanket got shredded by the vermin that inhabited the spa before i found out and put wire mesh in the pump compartment to keep them out. Should I be applying foam to restore the insulation ? Quote
