Daniel Erlandson Posted August 6, 2010 Report Posted August 6, 2010 the LCD screen on my california D1 spa is sort of shot. I can barely read the display as it scrolls. Is this a problem?? This is a used spa that we are just getting up and running after fixing a leak (hopefully that holds!). I have a replacement topside control from another D1 spa that does NOT fir my spa...bad ebay purchase, oh well. Any chance I can switch out LCD screens? Anybody ever try to cannibalize these things? dan Quote
THE SPA GUY Posted August 6, 2010 Report Posted August 6, 2010 Daniel, don't think that will work, by trying to switch out lcd , the problem will be matching to the board , you won't be able to work with that. what is your serial number, i can forward you the right number you need... Quote
Daniel Erlandson Posted August 9, 2010 Author Report Posted August 9, 2010 Daniel, don't think that will work, by trying to switch out lcd , the problem will be matching to the board , you won't be able to work with that. what is your serial number, i can forward you the right number you need... Thanks for the reply...guess I was hoping to NOT spend $300 on a new controller. My info is Dimension One 030-CALU-232-GM-71583-1 California Ultralife Top control: Gecko 0201-000002 Serial: 000250390 Model TSC-24 Option AD-NO WG13407-7 Dan Quote
THE SPA GUY Posted August 12, 2010 Report Posted August 12, 2010 Dan i will folowup with D1 on this, i have not checked in about a week ...soon as i know will let you know.. Quote
THE SPA GUY Posted August 13, 2010 Report Posted August 13, 2010 Daniel you will need to go with the 1560-310 topside control and the overlay sticker number is 1560-350 hope this helps for what you need . but you are looking over 300.00 Quote
Daniel Erlandson Posted August 14, 2010 Author Report Posted August 14, 2010 Daniel you will need to go with the 1560-310 topside control and the overlay sticker number is 1560-350 hope this helps for what you need . but you are looking over 300.00 rigght...thanks for the info. The over 300 bit is why I was hoping to just replace the LCD! So then my next question is: If I can just barely see the display, am I really missing anything? dan Quote
THE SPA GUY Posted August 14, 2010 Report Posted August 14, 2010 Daniel you will need to go with the 1560-310 topside control and the overlay sticker number is 1560-350 hope this helps for what you need . but you are looking over 300.00 rigght...thanks for the info. The over 300 bit is why I was hoping to just replace the LCD! So then my next question is: If I can just barely see the display, am I really missing anything? dan No everything should still work at this time...just tough to see all modes.... Quote
