i just got home from work and i noticed my hot tub was running, but sounding a little odd... when i looked at the controller, the temp was all the way up to 102, and the jets were running full steam on "jets 2". i never heat my tub to 102, and i dont use the jets 2 setting. to much wake for me... when i attempted to reset the jets back to jets 1, the jets would momentarily shut off, then kick right back in again on jets two. i shut the power off at the breaker in an attempt to reset it, but to no avail. its a cal spa tub with a very basic balboa controler... ideas??
I was trying to remember whe i unfortunately sold there tubs... is it hot outside where you are, it could be thermal creep. some of the Cal spas pump 1 would turn on for filter cycles twice a day for 2 hours. and a couple of times during the day pump 2 turns on to churn up the water . i believe for 2 minutes....but it has been a few years now....The best thing to do is cal your local Cal Spa dealer and tell them your model and what it is doing,,,
