Accidentally Ran Hottub Pump Without Water
  • Please log in to reply
4 replies to this topic
#1 swindmiller
swindmiller
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 26 July 2010 - 04:49 PM
I drained our hot tub to clean it and left it empty overnight. I automatically runs for an hour a day on a timer...I forgot to turn that off so I think it ran for an hour :(
I am filling it back up now and the pump seems to be running ok. It is not full yet but I turned it on for a second just to check. It is a 2 speed motor and only the low speed would have turned on not the high.
Did I screw it up...what do I need to look for?
Thanks,
Scott
#2 Dnepr Dave
Dnepr Dave
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 524 posts
  • Gender:Male
Posted 27 July 2010 - 06:38 AM
You probably didn't hurt anything, you'll know for sure when it's full and you try it out.
Dave
2005 Caldera Kauai
#3 swindmiller
swindmiller
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 27 July 2010 - 08:31 AM
Dave
Cool, thanks.
It is full now and when I first turned it on it barely had any pressure. I remembered when I first got this pump new I was supposed to fill up the tub and "flood the pump" by loosening the pvc connector on it to let the air out. After this the pump seems to run fine with good pressure and no leaks.
Is there something I need to be on the lookout for?
Does that mean I dodged a big bullet??
Thanks for your reply.
#4 Dnepr Dave
Dnepr Dave
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 524 posts
  • Gender:Male
Posted 28 July 2010 - 06:45 AM
Usually what happens on a centrifugal pump, that is run for a long time dry, is that the shaft seal on the pump gets overheated and damaged. If your pump doesn't leak, you are OK. It doesn't sound like it ran enough to get hot anyway.
Dave
2005 Caldera Kauai
#5 swindmiller
swindmiller
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 28 July 2010 - 06:51 AM
Thanks alot for the help.
