ur_too_crazy Posted July 10, 2010 Report Posted July 10, 2010 Seem to have hit a snag with a Nature2 cartridge I had purchased for another spa. My other spa had an open type filter where you can adjust the height of the cartridge and slip it down. I never installed it in my old spa since I noticed a crack in the shell so it had to be replaced by another model spa (long story). The new spa (IST) has a different system....square skimmer with a flap that opens. My question is....can I just place the Nature2 cartridge in the skimmer basket? The new filter is the screw on type and a little smaller than the other. Its a chore just to get the filter in their and screwed on (very limited space).I cannot for the life of me get it in their with the cartridge> Quote
hottublady Posted July 11, 2010 Report Posted July 11, 2010 I don't see why not as long as it isn't possible for it to get sucked into the plumbing. Quote
primo Posted July 12, 2010 Report Posted July 12, 2010 Seem to have hit a snag with a Nature2 cartridge I had purchased for another spa. My other spa had an open type filter where you can adjust the height of the cartridge and slip it down. I never installed it in my old spa since I noticed a crack in the shell so it had to be replaced by another model spa (long story). The new spa (IST) has a different system....square skimmer with a flap that opens. My question is....can I just place the Nature2 cartridge in the skimmer basket? The new filter is the screw on type and a little smaller than the other. Its a chore just to get the filter in their and screwed on (very limited space).I cannot for the life of me get it in their with the cartridge> Be advised that the Nature2 Cartridges have 3 small slots in the bottom of their cartridges that line up with their cartridge holders "tabs" (work together). Quote
Kim Andi Posted July 12, 2010 Report Posted July 12, 2010 We have a spa that seems to have the type of opening you have, are you sure the entire housing cannot be moved into the tub to access the filter better and then put in the Nature2 cartridge? Quote
ur_too_crazy Posted July 13, 2010 Author Report Posted July 13, 2010 Be advised that the Nature2 Cartridges have 3 small slots in the bottom of their cartridges that line up with their cartridge holders "tabs" (work together). I see 2 slots tabs...don't understand exactly what I'm supposed to do with those We have a spa that seems to have the type of opening you have, are you sure the entire housing cannot be moved into the tub to access the filter better and then put in the Nature2 cartridge? I can't seem to move the housing (screwed in place to the side of the spa). Thanks for all your responses. If all else fails i guess I'll just throw it in the skimmer basket. I guess the whole purpose of this thing is that the water flow through it during a filter cycle. Quote
