rjohnson Posted June 17, 2010 Report Posted June 17, 2010 Hi there, I recently noticed that the pipe leading from my pool, to the filter is leaking, most likely from a joint. I was thinking of fixing it with silicone, and was wondering if that is a good idea, and if this place would be good for buying silicones online Quote
SteveM2690 Posted June 17, 2010 Report Posted June 17, 2010 hey, No do not use silicone it will not work. You will have to repair it yourself or have a company do it for you. You will have to cut the joint out and replace it with a coupling on either side. If that doesnt work or is too difficult to put back together without damaging anything else, use a mission coupling which is the rubber couplings with hose clamps on either side. steve Quote
