TomC Posted June 7, 2010 Report Posted June 7, 2010 Hi, In an attempt to ease my eczema we have just switched over to Hydrogen Peroxide. We have diligently been reading the posts on here about using Hydrogen Peroxide but we are a bit confused on the filter maintenance impacts. For example, we noticed something about TPS to clean the filters. What is TPS? Plus, is it written anywhere on how or how often to clean the filters. Is there anything else we should be on gaurd for when using HP? Thanks in Advance...Tom Quote
chem geek Posted June 8, 2010 Report Posted June 8, 2010 It's TSP which stands for trisodium phosphate. You can read more about that in Maintaining and Cleaning of Pool Filters which also applies to spa filters. Quote
cramp11 Posted June 8, 2010 Report Posted June 8, 2010 Tom, I change my filter once a week. I have two filters. One in the tub and the other soaking in 2:1 (water:peroxide). Spray it as clean as you can with the hose before you soak it. Cramp Quote
TomC Posted June 8, 2010 Author Report Posted June 8, 2010 Cramp, I gather you just leave it in the soaking soltuion until it is time to pop it back into the tub (or do you soak it for a few hours, remove it, and let it sit until you are ready to swith it)? Do you do the TPS step? If so, where can I find this TPS stuff? Oh yeah, I gather that you have to add new cleaning solution each time you clean a filter, or can you just keep using the same solution over and over? Thanks Again...Tom Quote
Peteyboy Posted June 9, 2010 Report Posted June 9, 2010 I prefer to use a degreasing filter cleaner. Oils clog filters more than anything. I soak overnight, rinse very well and let it dry. I keep 2 sets of filters. Quote
TomC Posted June 14, 2010 Author Report Posted June 14, 2010 Hey Cramp, Do you happen to have a name for the solution you clean the filter with? Plus, do you just soak it in a bucket? The reason that I ask is because I have received a recommendation to soak the filters in a Hydrogen Peroxide/water bath. HP tends to be expensive though, and since it is expensive, I was thinking I might need a special vessel to house the solution (which I can buy). The HP solution so far has been great. The last step is to figure out how to clean the filters so any light you can shed on it would be greatly apprecaited. Thanks in Advance...Tom Quote
TomC Posted June 14, 2010 Author Report Posted June 14, 2010 Ooops, it was Peteyboy who responded in regards to the filter cleaning, not Cramp. It seems like you both have a handle on it, any advice from either of you is appreciated ;o) Thanks...Tom Quote
cramp11 Posted June 24, 2010 Report Posted June 24, 2010 I've tried TPS once, but didn't really notice any difference. Maybe I didn't use enough. I find that the hose blasts 90% of the crud out of the filter. Like Peteyboy, I rotate 2 filters. I don't just soak it overnight though. I have one in the tub and one in the 2:1 solution. When I need to change, I swap them. I have a 3rd filter and am tempted to try the idea of having one in the tub, one in the solution and one dried out waiting to go in the tub. HP is def expensive and I hate it when I have to change the 2:1 solution. Typically when I take a filter out, the water level lowers a bit. I just top it off with HP. You have to change it eventually though. My 'bucket' is a cardboard tube with a plastic bag in it. I couldn't find a container tall enough to submerge the whole filter in unless the container was really wide. That would have taken a whole jug of HP. Not happening. My dealer was supposed to be having a custom container made. Never heard back. Quote
connor Posted September 21, 2022 Report Posted September 21, 2022 we switched to the H2O2 many years ago but recently are getting rashes. from longer sits in the tub. test strip are black ( way past the 100 pm ) Quote
