Steps Staining - All Swimming Pools Types - Pool and Spa Forum
(January 9, 2015) POOLSPAFORUM.COM SITE UPGRADE!
Steps Staining
  • Please log in to reply
9 replies to this topic
#1 openbahr
openbahr
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 06 June 2010 - 06:06 PM
my steps get an orange-ish stain on them and the pool store sells me a small $30 bottle of hot tub salt which i put in a sock and rub the stain and it
works great but disolves fast. and stain keeps coming back. does anyone have any clue what is causing it?
#2 Seahunt
Seahunt
    Spa Savant
  • Members
  • PipPipPip
  • 114 posts
Posted 07 June 2010 - 03:36 AM
Could it be yellow or mustard algae?
#3 wsommariva
wsommariva
    Spa Savant
  • Members
  • PipPipPip
  • 84 posts
Posted 07 June 2010 - 04:56 AM
I have a fiberglass pool. Brownish stains. Asorbic acid (vitamin C) removes them quickly but they come back. I'm told to use a metal sequestering agent, assuming the stains are iron or copper or tannin from trees. I'll try it next week. (apply a maintanance dose of SA every week.)
The products I used: Stainfree (AA); Metalfree, the sequestering agent.
I'm not saying that this will work, but maybe. As Seahunt says, maybe an algae.
#4 openbahr
openbahr
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 07 June 2010 - 05:17 AM
Fiberglass pool?
the pool is not fiberglass but the steps are.
I don't think it's an algae as it's not easy to get off that salt is the only
thing that works. Or a magic eraser.
Could it be tannins from a tree? I do have a tree that partially overhangs
the pool.
#5 wsommariva
wsommariva
    Spa Savant
  • Members
  • PipPipPip
  • 84 posts
Posted 07 June 2010 - 08:02 AM
Hardest part is determining what the stains are from. If they are metals, then you need that sequestering agent. So I'm told. As I stated I'm trying this next week.
#6 openbahr
openbahr
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 08 June 2010 - 12:54 PM
any progress yet?
#7 jkusmier
jkusmier
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 567 posts
Posted 08 June 2010 - 08:46 PM
openbahr - do you have a vinyl-lined pool? Are the stains located along the waterline or underwater? If underwater, it is likely a metal stain and you can disregard the rest of this.
If along the waterline, it may well be a scum line caused by sunblock. I have a 3-year old vinyl-lined pool w/ acrylic/thermoplastic steps (an acrylic shell underlaid w/ fiberglass for reinforcement; the upper/exterior surface is acrylic) and have experienced yellowish stains along the waterline in my step section. I find the same thing in my skimmer box - clean plastic is a magnet for oily sunblock residue. I experimented w/ a lot of things (vinyl/tile cleaner, baking soda, sodium bisulphate and muriatic acid) and finally settled on a process of coating the scum line w/ vinyl/tile cleaner, letting it sit for 2-3 minutes, then rubbing (but not scrubbing) w/ a Magic Eraser. The longer the scum line sits, the more time it takes to remove, so I tend to hit it once soon after bathers exit the pool and again a few hours later or the next morning.
Confirm whether the surface of your steps is fiberglass or acrylic. If fiberglass, I would NOT recommend using a Magic Eraser - it will dull and eventually strip the gel coat. No worries about using a Magic Eraser on acrylic, although I avoid scrubbing very hard and cleaning them excessively. The staining doesn't appear as often since I implemented a sunblock rule: no lotions allowed, only waterproof/resistant clear sprays, which must be applied a solid 5 mins before entering the pool. The stuff is like glue, once it dries it tends to last a couple of hours in total immersion. I shudder to think of what the waterline (and my filter media) would look like after a party w/ 10-15 people wearing lotions/oils.
Finally, don't ever use a Magic Eraser on a vinyl liner. A weekly rubdown w/ vinyl cleaner and a sponge is all you need.
#8 openbahr
openbahr
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 09 June 2010 - 01:51 AM
yes, its from the waterline down. all of the steps under water. and the skimmer plastic.
It cant be sunblock anyway because when I opened the pool, it was fine and then within a few days the stains came back. before anyone went in.
if its metals what do I do?
its a rust colored staining.
#9 wsommariva
wsommariva
    Spa Savant
  • Members
  • PipPipPip
  • 84 posts
Posted 09 June 2010 - 06:15 AM
I have not yet tried the Stainfree/Metalfree treatment as I am taking a short vacation. Once I do, I'll let you know the results. I know the Stainfree(asorbic acid) will remove the stains (probably iron/copper). I am hoping that the Metalfree maintanace treatment will keep them away.
#10 wsommariva
wsommariva
    Spa Savant
  • Members
  • PipPipPip
  • 84 posts
Posted 08 July 2010 - 06:00 AM
This is what worked for me, what I believe to be iron stains. Stainfree(asorbic acid) followed in one hour by metalfree per instructions.
As maintanance, weekly metalfree but a double dose. Single dose did not keep the stains away for the week.
My iron just tested at .3
website security
