Hot tub hottie Posted May 20, 2010 Report Posted May 20, 2010 I'm replacing the 2 inch o-rings and split nut union on my Balboa heater. The O-ring is rubber and the split nut union holds together a metal pipe (on the Balboa unit) and a PVC pipe. What kind of lubricant is safe to use on the rubber o-ring? I know Vaseline deteriorates rubber. Would a silocone lube be ok, or can I used cooking oil/Crisco, OR do I need to go buy some Plumbers Grease? I've read all different answers to similar questions on the plumbing forums. I don't want to use anything that will deteriorate the rubber o-ring faster than they normally deteriorate on their own. They are a pain to replace, not because putting in an o-ring is difficult, but because these particular o-rings that I have must be ordered on-line and take several days to be shipped (unless I pay $50 to overnight for a $1.29 part--no.) One other question: if water is trickling out of the Balboa metal housing, can I put the o-ring on, or should I want until both ends are dry, lube them up and then attach them? My boyfriend and I have money riding on this answer, so...can't wait to hear what you have to say! Thanks in advance for all responses, HTH (Hot tub hottie) Quote
david_bilton Posted May 20, 2010 Report Posted May 20, 2010 I'm replacing the 2 inch o-rings and split nut union on my Balboa heater. The O-ring is rubber and the split nut union holds together a metal pipe (on the Balboa unit) and a PVC pipe. What kind of lubricant is safe to use on the rubber o-ring? I know Vaseline deteriorates rubber. Would a silocone lube be ok, or can I used cooking oil/Crisco, OR do I need to go buy some Plumbers Grease? I've read all different answers to similar questions on the plumbing forums. I don't want to use anything that will deteriorate the rubber o-ring faster than they normally deteriorate on their own. They are a pain to replace, not because putting in an o-ring is difficult, but because these particular o-rings that I have must be ordered on-line and take several days to be shipped (unless I pay $50 to overnight for a $1.29 part--no.) One other question: if water is trickling out of the Balboa metal housing, can I put the o-ring on, or should I want until both ends are dry, lube them up and then attach them? My boyfriend and I have money riding on this answer, so...can't wait to hear what you have to say! Thanks in advance for all responses, HTH (Hot tub hottie) try magic lube a silicone lube you can do this wet or dry and give the srews on the split nut a little twist as well good luck Quote
Hot tub hottie Posted May 21, 2010 Author Report Posted May 21, 2010 I'm replacing the 2 inch o-rings and split nut union on my Balboa heater. The O-ring is rubber and the split nut union holds together a metal pipe (on the Balboa unit) and a PVC pipe. What kind of lubricant is safe to use on the rubber o-ring? I know Vaseline deteriorates rubber. Would a silocone lube be ok, or can I used cooking oil/Crisco, OR do I need to go buy some Plumbers Grease? I've read all different answers to similar questions on the plumbing forums. I don't want to use anything that will deteriorate the rubber o-ring faster than they normally deteriorate on their own. They are a pain to replace, not because putting in an o-ring is difficult, but because these particular o-rings that I have must be ordered on-line and take several days to be shipped (unless I pay $50 to overnight for a $1.29 part--no.) One other question: if water is trickling out of the Balboa metal housing, can I put the o-ring on, or should I want until both ends are dry, lube them up and then attach them? My boyfriend and I have money riding on this answer, so...can't wait to hear what you have to say! Thanks in advance for all responses, HTH (Hot tub hottie) try magic lube a silicone lube you can do this wet or dry and give the srews on the split nut a little twist as well good luck Thank you very much. I really appreciate your answer. Have a wonderful weekend! Quote
micksmith Posted June 30, 2011 Report Posted June 30, 2011 I had to contact where I purchase my o rings from and they said Servisol silicone greese. Quote
Dnepr Dave Posted June 30, 2011 Report Posted June 30, 2011 Ive used silicone grease on "O" rings for years, it works great! Dave Quote
PreservedSwine Posted July 1, 2011 Report Posted July 1, 2011 Nothing works well too. The heater doesn't need to be dry to install the o-ring/gasket. Quote
bfunke Posted July 3, 2011 Report Posted July 3, 2011 +1 on magic lube. I have a 60gm tube bought several years ago at Bart's in Litchfield Park Arizona. It's great stuff for neoprene o-rings and seals on pools and spas. I found it also works great on door hinges at the house. It is very sticky so use sparingly. A little goes a long ways. Quote
