Polaris Cleaner Choice
  • Please log in to reply
10 replies to this topic
#1 eastside
eastside
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 13 May 2010 - 02:06 PM
new person here....pool owner for 23 years, always used polaris cleaners. i am trying to decide between the polaris 380 or the 3900. would appreciate any comments of the two before i make the purchase. thanks in advance.
#2 Pool Clown
Pool Clown
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 2,707 posts
  • Gender:Male
Posted 13 May 2010 - 02:22 PM
I don't think Polaris makes a cleaner that just doesn't work. They are all good units, IMO. It basically comes down to what you can afford.
Factory Warranty/Service for:
#3 polyvue
polyvue
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 252 posts
  • Gender:Male
Posted 14 May 2010 - 09:42 AM
Regarding reliability all I ever read about is how wonderful the Polaris 280 is but if you've owned this model (or any of them, surely) you know how annoying they can be as well in terms of tiny parts (that break one a time) and the constant fiddling required to keep them operational. If I was buying new I'm sure I'd have to buy the 3900 because I like new, shiny things. Probably performs nearly as well or the same as the 280 or 380. What's an extra few hundred dollars? heh heh If you elect to purchase the 3900, please post back with your opinion.
~14,000 gallon in-ground 16'x29' white plaster Pool w/spa Aug 2007; Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main and 1.5HP (1.60 SF) spa pumps; Polaris 280 cleaner; Hayward Swimclear cartridge filter C4025; Tankless SP-18-4 electric heater; Hayward ColorLogic LED lights
Test Your Water, Then Treat
#4 txpoolguy
txpoolguy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 389 posts
Posted 14 May 2010 - 11:07 AM
Polaris has a pretty good reputation all around. I haven't used the 3900 yet, although it sure looks pretty. Choosing between the 280 and 380, I'd pick the 280. 280 is a good solid cleaner, and you'll save a few hundred bucks.
#5 AFiremanFirst
AFiremanFirst
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 384 posts
Posted 14 May 2010 - 01:36 PM
Just my opionion. But I love the letro legend. You can get it in a platinum version too, however the polaris 280 is probably the most purchased cleaner on the market. I'm assuming you're using a booster pump? The most common problems with all pressure cleaners or any cleaner for that matter is maintenance. Bearings wear out, tires wear out and bags are sensitive to chlorine. Letro's bag is not nearly as good as polaris, now you can buy an adapter and use polaris bags on letros. For your own info, letro high jacked polaris and their bearings are interchangeable, or most of their parts for that matter. 380 is a good cleaner back to your original question, the 3900 claims to be robotic, the only info I have heard about the 3900 is that it tends to "stick" to the walls better than the 380. Robotic means that it should learn your pool and clean every nook and cranny.
#6 BoatingDave
BoatingDave
    Spa Savant
  • Members
  • PipPipPip
  • 54 posts
Posted 20 May 2010 - 06:35 AM
Haven't used the 3900 but have the 380. It is a good unit. Happy with it.
#7 Swim 'N Save USA
Swim 'N Save USA
    Service Technician
  • Members
  • PipPip
  • 22 posts
  • Gender:Not Telling
Posted 05 June 2010 - 02:30 PM
we generally hear a few complaints regarding the gears within the 360 and 380 having plastic parts that break internally very quickly. From what I understand is the 3900 sport is supposed to be a much more rugged, longer lasting model (more money too, of course). If you would like, our service tech's can answer your question more in depth.
Palm Harbor Pool Service - Florida Pool Tech provides pool service and repair work to pools and spas in the Palm Harbor, FL area.
#8 Badpolaris
Badpolaris
    Junior Member
  • Members
  • PipPip
  • 15 posts
Posted 14 June 2010 - 11:20 AM
#9 Badpolaris
Badpolaris
    Junior Member
  • Members
  • PipPip
  • 15 posts
Posted 14 June 2010 - 11:26 AM
My Polaris broke after 6 weeks. It's been almost a month since I first contacted Polaris about warranty. They do not replace a defective 380 cleaner they need to "fix" it. When I complain about the lenght of tome to Pool Pro in Quakertown, PA he says " :Polaris has a specific set of rules to follow under warranty.
When I complain to Polaris, they say, " I'm sure it probably only needs a cleaning".
So after paying premium dollars for an inferior machine & WORSE WARRANTY SERVICE, I'm spending hours manually vacuuming the pool.
They may have made quality pool cleaners 23 years ago. My first Polaris 380 that came with the pool lasted only 4 years. The new one only a few weeks.
I strongly recommend you look other than Polaris for your future pool needs.
#10 PaulR
PaulR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 429 posts
Posted 15 June 2010 - 05:46 AM
My pool came with a 380 when we bought the house two years ago; don't know how old it is. It has needed some fussing with 2-3 times but the local shop has always been happy to do the fussing.
--paulr
#11 iwallace
iwallace
    Junior Member
  • Members
  • PipPip
  • 10 posts
Posted 15 June 2010 - 02:30 PM
...and for anyone wondering just how pretty it is, heres a video with all the bling.
