Tojo Posted March 25, 2010 Report Posted March 25, 2010 I have an LA spa [eclipse].it has a leak of which I have had to drain the water on several occasions,costly on a water meter.Do you know if there is some kind of shut off valve so you dont have to drain .I cant find one but if I new what to look for and where could be a help,not even sure if this spa has any such feature.Can you help thanks. Quote
Jeniffer1 Posted March 27, 2010 Report Posted March 27, 2010 hi, If you live in an area where there is hard tap water, then you really should be in the practice of draining your water heater at least a few times a year. Draining the water heater gets rid of the hard water mineral and rust deposits that build up and reside at the bottom of your water heater's tank. The longer this sediment sits inside the tank, the shorter the life span of your water heater will be. Not to mention the agony of cleaning sinks, showers and tubs with rusty mineral build up! Thanks, Quote
