cosmic Posted December 12, 2009 Report Posted December 12, 2009 G'day, I have a fibreglass inground pool, which I'd estimate is 20 years or so. It has a number of cracks etc though none are causing water loss. What is causing a problem however, is that the skimmer box appears to be collapsing. Instead of a circular shape for the basket to sit in, it is a semi-circle, with 2 "straight" sides. Whilst fitting inside the skimmer, the basket is not forming a proper seal, and leaves/etc are getting under the basket. My Question: Can I "push" the fibreglass back out into its proper shape? Will that just make it break? Can it be "patched" or is this going to be a big issue? Thanks cosmic Quote
dorway Posted January 15, 2010 Report Posted January 15, 2010 G'day, I have a fibreglass inground pool, which I'd estimate is 20 years or so. It has a number of cracks etc though none are causing water loss. What is causing a problem however, is that the skimmer box appears to be collapsing. Instead of a circular shape for the basket to sit in, it is a semi-circle, with 2 "straight" sides. Whilst fitting inside the skimmer, the basket is not forming a proper seal, and leaves/etc are getting under the basket. My Question: Can I "push" the fibreglass back out into its proper shape? Will that just make it break? Can it be "patched" or is this going to be a big issue? Thanks cosmic Quote
dorway Posted January 15, 2010 Report Posted January 15, 2010 G'day, I have a fibreglass inground pool, which I'd estimate is 20 years or so. It has a number of cracks etc though none are causing water loss. What is causing a problem however, is that the skimmer box appears to be collapsing. Instead of a circular shape for the basket to sit in, it is a semi-circle, with 2 "straight" sides. Whilst fitting inside the skimmer, the basket is not forming a proper seal, and leaves/etc are getting under the basket. My Question: Can I "push" the fibreglass back out into its proper shape? Will that just make it break? Can it be "patched" or is this going to be a big issue? Thanks Sounds like your concrete pool deck is moving. Concrete expands & cotracts according to temperature. I inspected a pool for an attorney & his client just last week with this issue being one of many I reported. You may want to strongly consider replacing the skimmer, repairing the cracks , & resurfacing the pool. If you don't, get ready for even bigger problems that will cost you big bucks to remedy. cosmic Quote
