How Long To Run Filter
  • Please log in to reply
6 replies to this topic
#1 hrustar
hrustar
    Spa Savant
  • Members
  • PipPipPip
  • 141 posts
Posted 01 December 2009 - 06:50 PM
Wondering how long most people run their filter cycle for each day.
I have a 24 hr circulation pump plus Ozonator.
My filter runs twice a day for periods of 2,4,6,8 hours.
Right now i run it twice a day for four hours. Sees a bit much. I have one to two people in the spa day for about 45 minutes at a time.
Please share your usage.
#2 sdriv
sdriv
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 01 December 2009 - 08:01 PM
QUOTE (hrustar @ Dec 1 2009, 06:50 PM) <{POST_SNAPBACK}>
I have the same set-up and my cycles are set for 2-2hr and 2-15 min cycles. Seems to work for me
#3 The Pup
The Pup
    Spa Savant
  • Members
  • PipPipPip
  • 115 posts
Posted 01 December 2009 - 08:12 PM
The manual for my "new" spa states the same thing...but I was able to set it to run 1hr every 12hrs (below the manufacturer's recommendation of 2hrs every 12hrs). It has been a year and so far...no issues of concerns. The spa rarely drops more than 1-2F between cycles at 100F (420 gallons as filled) and I have yet to find any slime, scum, debris or film. I can go beyond 5 months between refills (with a load of 2 people, 3-5 times per week for 20-50 minutes). On this spa, I am averaging around 140-160kWhrs per month.
#4 AMG
AMG
    Spa Savant
  • Members
  • PipPipPip
  • 73 posts
Posted 01 December 2009 - 09:34 PM
Maybe a spa expert can tell me what this really means? On my HotSpring Grandee, I don't have a filter option. When the circ pump is running, it is always filtering. Do some spa's not work like this? Should I be going out once a day or more and hitting the "clean" button (runs for like 15-20 minutes and turns off), or is hot spring good the way it is?
#5 Peteyboy
Peteyboy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 460 posts
  • Gender:Male
Posted 02 December 2009 - 06:06 AM
QUOTE (AMG @ Dec 1 2009, 10:34 PM) <{POST_SNAPBACK}>
The clean button runs the jets for 10 minutes.
Any spa that has 24 hour circulation shouldn't need a filter cycle. It couldn't hurt to run it for an hour twice a day but IMO anymore than that wouldn't make a big difference.
HotSpring has used 24 hour circulation since 1989 and never needed a filter cycle.
If you have ozone with 24 hour circulation - all the better.
spas are electrical devices and can be dangerous to repair - please use this advice at your own risk
Pete
Spa Tech since 1987
Spa Repair Services
Indialantic, FL
#6 Mikey_in_NY
Mikey_in_NY
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 298 posts
Posted 02 December 2009 - 09:19 AM
QUOTE (hrustar @ Dec 1 2009, 09:50 PM) <{POST_SNAPBACK}>
I have same setup. As other posters have said the 24 HR circ pump is constantly filtering, and also heating (at least on my Sundance). The 2 main pump auto-filtration cycles are set for twice a day for 30 minutes, which is the default factory setting. Water is 11 weeks old now and no issues at all with quality. Tub is used every day for 30-40 minutes by up to 3 people.
So I suspect you're overdoing it.
#7 Susanj
Susanj
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 09 June 2016 - 11:52 AM
I thought (from a previous thread on this forum) that there can be a concern with ozonators and the forming of possibly cancer- causing bromates. This is what was concluded-
"If you only run ozone when the filter cycles, and the ozone generator is not as big as a refrigerator, you have no worries."
So then wouldn't 24 hr filtration/circulation be too much?
