Hot Tub Scale - Hot Tub Water Chemistry - Pool and Spa Forum
(March 25, 2015) POOLSPAFORUM.COM IS INSTALLING A MAJOR SOFTWARE UPGRADE.
EXCITING NEW FEATURES ARE JUST AROUND THE CORNER.
Hot Tub Scale
  • Please log in to reply
3 replies to this topic
#1 Reg Rumble
Reg Rumble
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 December 2006 - 09:32 AM
This is my first post on this board. We have had our old fiberglass tub for several years and after trying every bromine/ clorine product on the market we finally discovered Baqua Spa and have never been hapier (except that we cannot buy it in Canada and have to go to the states once a year for supplies). I have noticed over the past year we are getting a scale build up on the surface of the tub. The last time I drained it I tried to scrub the walls with CLR but it did not remove much. Is there something to add to the water that will gradually remove scale or is the only answer to use a sander sad.gif Thanks for the help and happy tubing
#2 dynamictiger
dynamictiger
    Junior Member
  • Members
  • PipPip
  • 39 posts
  • Gender:Male
Posted 07 December 2006 - 01:36 PM
Fiberglass likes acid. Next time you empty it, try cleaning it with a 10 to 1 Muriatic acid solution and see if the scale weakens or lifts.
HTH
#3 hottub.pool_boy
hottub.pool_boy
    Spa Savant
  • Members
  • PipPipPip
  • 126 posts
  • Gender:Male
Posted 07 December 2006 - 07:20 PM
Also, next time it's empty, try a spot of the shell with your baqua filter cleaner and a rag, think you'll find the answer.
OEM HotSpring Stuff and SpaGuard Chemicals Online
#4 Pool Owner
Pool Owner
    Junior Member
  • Members
  • PipPip
  • 19 posts
  • Gender:Male
Posted 13 December 2006 - 03:49 PM
To help removing scale before draining your spa, try ScaleTec Plus. You should double check that it is okay for plastic/fiberglass shells. It is from McGrayel Corporation, Easy Care Products Division, which is located in Fresno, CA, USA. Their website is www(dot)mcgrayel(dot)com; however, it has had problems every time Iíve checked. I have found this product at a few local pool supply retailers and just today my local Leslieís. Reportedly it is real good at removing scale with natural chemicals, which are less likely to create other water chemistry problems. Please reply to your post with your solution (especially if you used this product and like/dislike it).
Pool Owner
Orange County, CA, USA
website security
