Just over a month into have the tub, we saw some white floaty things in the tub. We spiked the Peroxysan (as per the dealer's advice) but it just kind of make them go into a ball and float. We'd clean them up and they'd come back.
After a month of trying to fight it (and a whole lot of Peroxysan) we decided to drain the tub. Before we did, we bought a chlorine shock and spiked the ppm to ???. (strip only goes to 10 ppm and it was very black)
We ran the jets on high for about 60 min alternating the air on/off.
We drained the tub and hosed the sides down multiple times.
We sprayed the inside of the tub and cover with 5:1 ratio Peroxysan.
We shocked both filters with a high ppm of chlorine as well and rinsed them both multiple times.
We filled the tub again with just hose water this time (nothing from the hot water tank) and added 12 cups of Peroxysan. (our tub is about 1100L)
We checked the tub today and we had balls of white crud floating around in the tub. I'm guessing it was in the pipes. Our dealer advised us to pour in another 12 cups of h2o2. (that's $50 worth
I changed the filter and am hoping that the floaters are just dead remains from the pipes. (that's what the dealer says anyways)
Our h2o2 ppm is about 400 right now. We're supposed to keep it at 100 ppm. We haven't even used the tub since the refill. (yesterday)
If we still have these things by the end of the week, we're going to take back what we have left of the Peroxysan and switch to bromine. As much as I love not smelling the chemicals, I can't bath in a pool of snot.
Any ideas of why the tub still has stuff in it? I don't understand why the chlorine didn't fry it. Maybe it is dead stuff just breaking loose from the pipes.
If I switch to bromine, do I have to drain and start all over again?
I have 8 L of Peroxysan left. At $133 for 16L, I want this to work, but from what I've seen on here about it... I'm doomed.
Sign In
Register
Help
MultiQuote
