I searched for an answer here but didn't find one.
Just noticed there are HOLES in one of my panels (24' AG, SWG) and the liner is showing. The damage is at the bottom where the panel meets the ground and is adjacent to where I add the sanitizer and muratic acid. However, I have not had any accidental spills of any kind. The holes vary from pea to quarter sized. Salt corrosion?
Does anyone know of a possible 'bandaid' patch fix?
Thanks,
Dennis
PICTURES: http://s277.photobuc.../miscellaneous/
Page 1 of 1
Aluminum Wall Panel Damage
#2
Posted 06 November 2009 - 04:11 AM
You could try to patch it, but it will be difficult to get an even surface on the inside and it could ultimately damage the liner. You said it was just one of the panels, so it's not one of those pools where it's just one solid sheet of aluminum stretched all the way around? Is there any way to contact the manufacturer to order a replacement panel? More expensive than a patch in the short term, but probably cheaper in the long run if it damages the current liner.
#3
Posted 06 November 2009 - 06:59 PM
Probably galvanic corrosion. You could add a magnesium anode to help reduce further damage.
You can't manage what you don't measure. Get a good test kit. I recommend the Taylor K-2006 for chlorine or the Taylor K-2106 for bromine.
#4
Posted 09 November 2009 - 03:47 PM
QUOTE (quantumchromodynamics @ Nov 6 2009, 09:59 PM) <{POST_SNAPBACK}>
Seems like there would be corrosion on other areas of the pool instead of one place.How would an anode be installed? On the outside? Thanks.
Esther Williams 24' AG, ChlorEase SWG
Lansing, Michigan
Lansing, Michigan
#5
Posted 09 November 2009 - 04:43 PM
Corrosion can end up on small areas for a variety of reasons. There may have been damage to the paint at the area, or a mixture of air and water etc. An anode could be connected to the aluminum by a wire. The anode should be buried in the ground near the pool where the ground is the wettest. You could also put one near the corroded section. You could connect the anode to the grounding wire.
#6
Posted 11 November 2009 - 02:31 PM
QUOTE (quantumchromodynamics @ Nov 9 2009, 07:43 PM) <{POST_SNAPBACK}>
Thank you. I own an aluminum boat and have some zinc to use. Will connect one to the bottom of the panel near the trouble. Q: How much zinc to use? How to repair from the outside?
Lansing, Michigan
Lansing, Michigan
Page 1 of 1
Sign In
Register
Help
MultiQuote
