Impeller Removal
  • Please log in to reply
18 replies to this topic
#1 ncaaref
ncaaref
    Junior Member
  • Members
  • PipPip
  • 23 posts
Posted 24 September 2009 - 08:17 AM
I have 98 Sundnce optima and Pump number 2 needs a new impeller I have the pump out of the spa but unlike pool pumps, I can't get the rear cover off of the pum to hold the shaft to turn the impeller to loosen it. It it a Theramax II 2.5 HP pump. Does anyone know how to get the impeller off?
Thanks
#2 rusty-D
rusty-D
    Junior Member
  • Members
  • PipPip
  • 38 posts
Posted 24 September 2009 - 10:43 AM
can you see the shaft between the motor and the volute? I normally hold it from there with needle nose vicegrips and works fine. I also have use a long screwdriver to hold the fan and uscrew the impeller, but that is only if the fan is made out of metal, I don't want you perform this, if it's made out of plastic... good luck.
#3 ps558
ps558
    Spa Guru
  • Validating
  • PipPipPipPipPip
  • 1,121 posts
Posted 24 September 2009 - 12:12 PM
QUOTE (rusty-D @ Sep 24 2009, 02:43 PM) <{POST_SNAPBACK}>
As stated above works best. Since you are replacing the impeller it there is little room for the vice grips, you break the plastic throat with a screwdriver to gain better access the motor shaft.
If it really stuck. turn the pump sitting on the wet end and soak with liquid wrench for a while. If that still doesn't work you might have to drill the impeller off
#4 ncaaref
ncaaref
    Junior Member
  • Members
  • PipPip
  • 23 posts
Posted 24 September 2009 - 12:15 PM
Yes the impeller is made from plastic so it look like the second is my option. I really can't believe that the rear Cover can't be removed like a pool pump this makes it so easy.
#5 n1oty
n1oty
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 475 posts
Posted 24 September 2009 - 01:41 PM
QUOTE (ncaaref @ Sep 24 2009, 04:15 PM) <{POST_SNAPBACK}>
Try popping the little cover off. It is located dead center at the rear of the pump. It will reveal a slotted shaft.
John
#6 ncaaref
ncaaref
    Junior Member
  • Members
  • PipPip
  • 23 posts
Posted 24 September 2009 - 03:24 PM
QUOTE (n1oty @ Sep 24 2009, 05:41 PM) <{POST_SNAPBACK}>
John
Will Do!
#7 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,132 posts
Posted 24 September 2009 - 05:57 PM
QUOTE (n1oty @ Sep 24 2009, 04:41 PM) <{POST_SNAPBACK}>
John
Or a shaft with 2 flat sides for a wrench. Never ever hold the shaft with a vice grips or stick a screw driver in the fan blades or anything like that. Always go to the opposite end of the shaft and hold it there.
Part Time
#8 RFD100
RFD100
    Junior Member
  • Members
  • PipPip
  • 31 posts
Posted 25 September 2009 - 06:16 AM
I replaced both pump wet ends on my 2003 Sundance Marin. The impellers were screwed on with left handed threads. I used a pair of vise grips to hold the shift and a lager pair of channellocks and it screwed right off.
#9 rusty-D
rusty-D
    Junior Member
  • Members
  • PipPip
  • 38 posts
Posted 25 September 2009 - 06:22 AM
Al pumps are different , I mostly worki with Starite pumps which don't have access from the back since they have the speed switch system on the back, that is why I always do use visegrips, hey! whatever it works!... good luck
#10 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,132 posts
Posted 25 September 2009 - 06:47 AM
QUOTE (rusty-D @ Sep 25 2009, 09:22 AM) <{POST_SNAPBACK}>
There is always access to the back of the shaft. It is more difficult to get to on some than others.
Part Time
#11 dotdog2
dotdog2
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 25 September 2009 - 10:35 AM
Often when I cant hold a shaft like on an alternator or motor or anything of that nature an air powered impact gun will take it right off or put it back on tight. There is always a way to hold the shaft but when I dont feel like it I just hit it with the impact gun and it always pops right off.
#12 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,132 posts
Posted 25 September 2009 - 01:13 PM
QUOTE (dotdog2 @ Sep 25 2009, 01:35 PM) <{POST_SNAPBACK}>
But there is no nut on an impellor. The threads are built into the impellor.
Part Time
#13 n1oty
n1oty
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 475 posts
Posted 25 September 2009 - 01:26 PM
QUOTE (rusty-D @ Sep 25 2009, 10:22 AM) <{POST_SNAPBACK}>
But this guy says he has Sundance theramax pumps, which means these are Aquaflo XP2's. There has to be a cover on the back and the slot in the rear of the shaft will be revealed.
John
#14 dotdog2
dotdog2
    Junior Member
  • Members
  • PipPip
  • 34 posts
Posted 25 September 2009 - 02:56 PM
QUOTE (Roger @ Sep 25 2009, 02:13 PM) <{POST_SNAPBACK}>
Sorry, didnt realize that.
#15 mrfixit
mrfixit
    Spa Savant
  • Members
  • PipPipPip
  • 88 posts
Posted 26 September 2009 - 12:43 PM
If the impellor is siezed onto the shaft ( which it often is) and you cannot get a pair of vice grips between the wet end and the motor housing, you will need to either remove the rear of the motor, or break the impellor to get it off. Drilling the impellor is a good idea, and alot less work than removing the rear cover of the motor. Putting a screw driver in the end of the shaft will probably not work because you a human hand cannot put enough force into that screwdriver to hold it when the impellor is siezed onto the shaft.
However, if you decide that you do want to remove the rear cover of the motor, there are usually 2 or 3 slots on the edge of the rear cover where you can fit a screwdriver into. Carefully pry the rear cover open little bits at a time as you work your way around the cover. There, you can get vice grips onto the shaft. If you take this route, you may as well change the bearings while it is broken open.
Good luck.
#16 ncaaref
ncaaref
    Junior Member
  • Members
  • PipPip
  • 23 posts
Posted 30 September 2009 - 08:52 AM
Ok Guys I was able to hold the shaft with a pair of vice grips and turn the impeller with little effort and it came right off. Now I have a new problem. I replaced the seal kit, impeller and wear ring. Now when I turn the pump on I have great flow but the pump sound horrible very loud, roaring noise? I am Puzzled! any Suggestions?
#17 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,132 posts
Posted 30 September 2009 - 06:04 PM
QUOTE (ncaaref @ Sep 30 2009, 11:52 AM) <{POST_SNAPBACK}>
Did you put any Magilube on the new seal? Did you buy a quality seal? Did you bend the shaft or mar it? Shoulda used the nut or slot on the other end.
Part Time
#18 bart6453
bart6453
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 395 posts
Posted 30 September 2009 - 06:22 PM
Hmmm...most likely cockpit error. I am thinking something is not right from you not assembling it properly. I would go back and check my assembly, and clearances, look for new wear spots from parts that are contacting each other in the impeller assembly.
Just an idea.
It's gonna be okay....trust me!
#19 ncaaref
ncaaref
    Junior Member
  • Members
  • PipPip
  • 23 posts
Posted 01 October 2009 - 04:05 AM
Shaft not bent, and no mag lube on the seal.
