Once you get used to doing the cyanuric acid test, here is a way to do the test that will use less reagent.
01) Fill the comparator tube to the 4.5 ml line with pool water.
02) Add cyanuric acid reagent to the 9 ml line.
03) Cap and mix for 30 seconds.
04) Look into the tube to see if the dot is visible.
05) If the dot is not visible, shake out a little bit of water and look again.
06) Continue until dot is visible.
This way uses only 4.5 ml of reagent versus 7 ml of reagent. The Taylor test kit comes with 44.36 ml of reagent. Using 7 ml, you can do 6.337 tests. Using 4.5 ml, you can do 9.857 tests.
