Hot Tub Shell Crack And Leak: How To Repair?
  • Please log in to reply
14 replies to this topic
#1 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 07 August 2009 - 04:46 PM
Hey all,
I have 2 cracks at the bottom of one seat in my hot tub. Each crack is about 3-4" long and it is causing a leak on the underside of the tub. I just looked underneath and it is dripping just below each crack.
My hot tub is a costco keys backyard. I believe it is acrylic on the surface. The underside of the tub is colored yellow/brown-ish. Not sure if this is fiberglass? Seems like a one piece tub to me.
Anyway....how should I repair this?
Thanks,.
#2 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,135 posts
Posted 08 August 2009 - 04:41 AM
QUOTE (mader @ Aug 7 2009, 07:46 PM) <{POST_SNAPBACK}>
Hey all,
Thanks,.
Send it back to Costco for a full refund. Don't bother trying to fix it. There are plenty more problems coming. Start with a new one if it's more than a few years old.
Part Time
#3 JerimiahR
JerimiahR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 495 posts
Posted 08 August 2009 - 08:32 AM
The Costco based spas aren't the absolute best way to go, as a lot of their manufacturers frankly go bankrupt. I believe Keys was one of them.
Ultimately though, if you have 3-4" cracks in the bottom of the spa, although they can be patched, there really is no guarantee they don't just split back open again. It can be a lot of work to properly repair those cracks, with absolutely no guarantee the patch holds. Could last 3 days, could last 3 years. There's really no guarantee.
If your spa is relatively new, Costco has a pretty good refund/return policy. If it's something you can't get replaced or refunded, I'd consider shopping one of your local hot tub dealers for a new spa. Unless of course you're really handy and just want to try patching it anyways.
EDIT: I would have sworn I read that Keys Backyard filed for bankruptcy at some point. But apparently they're the Home Depot hot tub now. smile.gif Maybe they'll warranty the spa... biggrin.gif
http://keys-spas.com/default.jsp
Jerimiah Reece
Mountain Hot Tub
#4 JerimiahR
JerimiahR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 495 posts
Posted 08 August 2009 - 08:38 AM
Okay here's where I read about the bankruptcy. I knew I wasn't going nuts. smile.gif
http://www.poolspane...112topnews.html
Wow, even found an "Involuntary" US Banktruptcy Court Order...
http://keys.pszjlaw......ion Order.pdf
Jerimiah Reece
Mountain Hot Tub
#5 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 08 August 2009 - 12:01 PM
Ya, I hear you guys. But a built a deck around it and removing it would be a bear.
The cracks are in a specific spot. Its more or less a 1 ft sq section of the tub that houses the volcano jet. It juts out on 2 sides, and seems to be an obvious area to sag. I can tell from underneath it doesn't look to be supported directly to the frame of the hot tub. My thought is to add a 1' pressured treated 2x4 to support that area, and then patch the cracks.
I'm not sure what kind of acrylic patch I need, do I need to seal the underside as well, etc?
#6 JerimiahR
JerimiahR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 495 posts
Posted 08 August 2009 - 12:21 PM
I'm by no means the expert on this sort of thing. Our technician who does crack repairs (and does a fantastic job at that) generally shy's away from doing them in the first place. Generally, a properly patched crack should actually be patched from the backside, not the water side.
My guess is, your spa likely has a fiberglass backing under that acrylic shell. So you'll probably be using fiberglass for part of your patch work I'd be guessing.
Perhaps someone else with more expertise in this area can give you some advice.
Jerimiah Reece
Mountain Hot Tub
#7 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 08 August 2009 - 12:47 PM
QUOTE (JerimiahR @ Aug 8 2009, 12:21 PM) <{POST_SNAPBACK}>
Yes, thanks. I've been scouring the web for "how to articles". Seems like I have to patch the underside with a fiberglass patch and the tub side with an acrylic patch. Maybe I can use one on both sides.....still not sure.
#8 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,135 posts
Posted 08 August 2009 - 01:50 PM
QUOTE (mader @ Aug 8 2009, 03:47 PM) <{POST_SNAPBACK}>
Return it to Costco...trust me your problems have just begun.
Part Time
#9 UK Arctic Dealer
UK Arctic Dealer
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 09 August 2009 - 07:52 AM
QUOTE (Roger @ Aug 8 2009, 05:41 AM) <{POST_SNAPBACK}>
Hey all,
Thanks,.
I am with Roger on this one. The best thing about Costco tubs is the return policy. Give them it back and let them worry about it.
#10 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 09 August 2009 - 12:17 PM
I called Costco today. They said I can bring to my local store or they will pick it up. Not sure how I can get it out of my deck though.
I did get to examine the 2 cracks closely from above and blow. There look to be caused by the second step into the tub. That step has a small bit of inflection when you step in it. That stress appears to transfer to the 2 cracks just below the step. From underneath, I can see that the tub is not really supported at the spot, hence the inflection when you step on it. I cut a couple of short 2x4s and shimmed them in between the shell and the frame. That has helped some, but not sure if it will take all future stress off of it. My plan would be to seal the crack and if the stress is reduced or eliminated, it should last.
Wondering if re-sealing the crack impacts the return at costco?
If you saw how its built into my deck, you would try a couple of things to fix it too!
#11 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 10 August 2009 - 02:26 PM
So in my infinite wisdom (or stupidity) I am attempting the repair myself. If this does not work, I am returning the costco (and taking apart part of my deck).
I added two ~7" 2x4's between the PT wood frame at the bottom of the tub and the underside of the shell where the stress is present. I then sprayed a couple cans of wide gap foam spray into the area. I hit around where the added 2x4s touch the underside if the shell.
Then I drilled small holes at the end of each crack for relief. Then, I got an acrylic tub and shower crack repair kit....mixed that stuff up, and applied it the cracks. Waiting for that the dry, sand, finish.....then refill.
#12 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,135 posts
Posted 10 August 2009 - 02:57 PM
QUOTE (mader @ Aug 10 2009, 05:26 PM) <{POST_SNAPBACK}>
Sounds good. May the force be with you my son!
Part Time
#13 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 11 August 2009 - 01:14 PM
Patch is complete. I'll be doing a test fill tonight!
One wild card is the heater. I had to remove it (and the section of pipe it is attached to) to get access to the repair spot. Well, I didn't pay that close attention to when I removed it, but it seems like its back right.
#14 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,135 posts
Posted 11 August 2009 - 02:46 PM
QUOTE (mader @ Aug 11 2009, 04:14 PM) <{POST_SNAPBACK}>
Yea those tubs are kinda messy/morphadite plumbing in the equipment bay. You'll know when you fire it up if its right.
Part Time
#15 mader
mader
    Spa Savant
  • Members
  • PipPipPip
  • 86 posts
Posted 13 August 2009 - 08:34 AM
Update. The cracks have been patched. I refilled last night and no leaking as of this morning. I took a soak last night to enjoy the fruits of my labor. I will feel more confident in the fix after about a week of no leaking, but so far so good!
