El Neno Posted July 15, 2009 Report Posted July 15, 2009 I am getting the Service code 123 I have cleaned the unit, Aqua Pure 1400, in acid diluted, and cleaned the sensor. Unplug, checked, wiped off prongs and plugged in the DC cord. What's up? Quote
Pool Clown Posted July 16, 2009 Report Posted July 16, 2009 I am getting the Service code 123 I have cleaned the unit, Aqua Pure 1400, in acid diluted, and cleaned the sensor. Unplug, checked, wiped off prongs and plugged in the DC cord. What's up? how old is the cell? Quote
ps558 Posted July 21, 2009 Report Posted July 21, 2009 I am getting the Service code 123 I have cleaned the unit, Aqua Pure 1400, in acid diluted, and cleaned the sensor. Unplug, checked, wiped off prongs and plugged in the DC cord. What's up? there is a small board inside the unit that has stopped putting out dc volts for the cell. That is what service code 123 means. You can test this with a volt meter on dc scale were the cell cord is connected. make sure the unit is trying to generate. Quote
Pool Clown Posted July 22, 2009 Report Posted July 22, 2009 A 123 service code is extremely low current to the cell. Meaning that the cell is not drawing current from the back board. Quote
ps558 Posted July 22, 2009 Report Posted July 22, 2009 A 123 service code is extremely low current to the cell. Meaning that the cell is not drawing current from the back board. If the board fails there is no power for the cell to draw current. no voltage no current Quote
Pool Clown Posted July 23, 2009 Report Posted July 23, 2009 If the board fails there is no power for the cell to draw current. no voltage no current Thats interesting, Have you changed a back board that was giving you a cell error code before? Quote
ps558 Posted July 23, 2009 Report Posted July 23, 2009 If the board fails there is no power for the cell to draw current. no voltage no current Thats interesting, Have you changed a back board that was giving you a cell error code before? Yeah I did, it would seem the cell would be bad because of the code. so I used a amprobe to test first and it was 0. I knew the voltage changes of a Goldine unit when the cell is off and/or on. I tested the output dc volts from the board and it was 0. From my electric schooling if the is power(voltage) is 0, there is no way any device can draw amps. Quote
Pool Clown Posted July 23, 2009 Report Posted July 23, 2009 "I used a amprobe to test first and it was 0. I knew the voltage changes of a Goldine unit when the cell is off and/or on. I tested the output dc volts from the board and it was 0. From my electric schooling if the is power(voltage) is 0, there is no way any device can draw amps." Well yeah, I don't dispute that, but how did you know El nino's voltage is 0? Or are you trying to tell me 123 codes are always going to be Back boards? An old Chloromatic II made me chase my tail awhile back. It spit out every code for every part except the flow/salinity sensor, And of course that was what was bad. Quote
ps558 Posted July 24, 2009 Report Posted July 24, 2009 "I used a amprobe to test first and it was 0. I knew the voltage changes of a Goldine unit when the cell is off and/or on. I tested the output dc volts from the board and it was 0. From my electric schooling if the is power(voltage) is 0, there is no way any device can draw amps." Well yeah, I don't dispute that, but how did you know El nino's voltage is 0? Or are you trying to tell me 123 codes are always going to be Back boards? An old Chloromatic II made me chase my tail awhile back. It spit out every code for every part except the flow/salinity sensor, And of course that was what was bad. no not everytime of course not. Its just some error codes can be misleading. Just like the older Balboa false OH that was due to no snubber for the ozonators that used a ballast. Spa never overheated. On Jandy lx heater giving false codes because the blower went bad. The equipment isn't perfect and sometimes error codes need a closer look, just like your Chloromatic II Quote
michelb Posted June 10, 2010 Report Posted June 10, 2010 I started getting this error as well and my cell does appear to be clean. If the problem is the 'back board' is this something that can be fixed or do I need to replace the part? Any troubleshooting steps or suggestions you can provide are greatly appreciated. Quote
