bigsave21 Posted July 8, 2009 Report Posted July 8, 2009 Hello everyone, Just a quick question, I did a test of my water in my inground pool, which is a 16x28 inground. And the level of chlorine was 10 on the strip. We went swimming today and noticed that my eyes where cloudy and I can feel it in my throat. How can I bring down the level, and are we able to swim in it. Any idea's will help me. Thanks in advanance bigsave21 from Canada. Quote
Seahunt Posted July 9, 2009 Report Posted July 9, 2009 Just wait a day or two and retest. Did you remove the sources of chlorine (e.g., tabs in skimmer baskets, floats, ect.)? Do you know the CYA level in your pool? Quote
bigsave21 Posted July 9, 2009 Author Report Posted July 9, 2009 I shut off my chlorinator, for the day and also will for the next couple of days. I'll retest everyday to seee if the level goes down. thanks for the help. Quote
quantumchromodynamics Posted July 10, 2009 Report Posted July 10, 2009 What kind of a chlorinator do you have? If it is a trichlor feeder, is best to remove the tabs from the feeder because the tabs will continue to dissolve and the concentration will become dangerously high. Do not put wet tabs back in the bucket. Once tabs get wet they continue to dissolve and are dangerous. About 30 minutes before opening a trichlor feeder, you need to turn the feeder to full to allow any concentrated chlorine to be flushed out; otherwise, you could get chlorine gassed. You also need to get a real test kit that will test for free chlorine, combined chlorine, total chlorine, pH, alkalinity, calcium hardness and cyanuric acid. The strips are not going to give you enough information to avoid the kinds of problems that you are experiencing. Quote
