Petroleum Jelly On O-rings?
  • Please log in to reply
12 replies to this topic
#1 pinfish
pinfish
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 31 May 2009 - 10:02 AM
I just installed a new haywood sand filter. I used pvc couplers that I can unscrew next time. Can I lubricate the o-rings inside of the coupler with petroleum jelly (vasoline) or do I need a silicone product? Is it necessary to use anything?
#2 Pool Clown
Pool Clown
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 2,724 posts
  • Gender:Male
Posted 31 May 2009 - 10:14 AM
No petroleum products on o rings. use the Teflon based lube and very sparingly, just enough to make them slick. Thats only if you are rubbing the o rings against a sealing surface. Union o rings don't really need lube since they get sandwiched against a sealing surface, and don't really move.
Factory Warranty/Service for:
#3 pinfish
pinfish
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 31 May 2009 - 11:35 AM
Thanks, I thought that sounded weird. I bought some silicone plumbers grease, but may not even need it.
#4 Pool-newb
Pool-newb
    Spa Savant
  • Members
  • PipPipPip
  • 158 posts
  • Gender:Male
Posted 31 May 2009 - 06:32 PM
I got some stuff at the local pool store specifically designed for pool applications and it works great.
Check at your pool store.
~8,500 gal, ig, 12x24 vinyl, 1.5 HP Dual Speed Hayward Northstar, Wood-fired pool heater since Apr 09. Using Bleach and Muriatic Acid since I found CYA levels well above 100. Using electronic ORP/PH meter for testing as well as TF1000 DPD-FAS test kit for dosing. Got rid of major serious metal stains (TWICE now) from rusted out gas heater on the old vinyl liner . Poorly maintained till I got it. Apr 08. Here's what I did/do to revive and now maintain it:
- First went back to the pool school at Trouble Free pool and used the BBB method. I calculate the needed chemicals using The pool calculator
- Purchased and use a TF-100 from <link removed>
- Purchased Hanna pH/ORP for routine testing
- 25 May 09 installed SWG, and like it. ORP meters show negative numbers and are now not usable.
#5 Pool Clown
Pool Clown
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 2,724 posts
  • Gender:Male
Posted 31 May 2009 - 09:14 PM
QUOTE (Pool-newb @ May 31 2009, 07:32 PM) <{POST_SNAPBACK}>
A name would help... Magic lube perhaps?
#6 Pool-newb
Pool-newb
    Spa Savant
  • Members
  • PipPipPip
  • 158 posts
  • Gender:Male
Posted 01 June 2009 - 05:36 AM
Ooops, sorry. This one was Leslie's Pool And Spa Lube (Funny name when you think about it - why would a pool need lubricating?). Since that is a trademark name it will probably not be available in the other stores, but they will likely have something similar.
#7 txpoolguy
txpoolguy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 389 posts
Posted 01 June 2009 - 01:36 PM
bad news... The stuff you get at Leslie's, while it works well short term, will cause the orings to deteriorate rapidly. All mfgrs suggest a good silicone based lubricant. The red magic lube, or equivalent is great & lasts longer. Having said that, the orings themselves aren't terribly expensive, so if they fail, you can get new ones pretty cheap.
#8 Pool-newb
Pool-newb
    Spa Savant
  • Members
  • PipPipPip
  • 158 posts
  • Gender:Male
Posted 01 June 2009 - 03:30 PM
Wow, good to know and I'll keep my eye n the stuff I've done with it.
#9 Pool Clown
Pool Clown
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 2,724 posts
  • Gender:Male
Posted 01 June 2009 - 04:01 PM
For the exception of the lid o ring on the pump (screw on types), PLM series filters, and a few other instances, you don't need lube on o rings. I don't know why but there seems to be a reason why techs love to lather up o rings in lube. They don't need it! O rings are the seal not the lube. If you get a leak to stop by using more lube, You have only treated a symptom and not the cause.
eNd raNt...
#10 aquablue1
aquablue1
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 25 July 2009 - 09:35 AM
QUOTE (txpoolguy @ Jun 1 2009, 04:36 PM) <{POST_SNAPBACK}>
Hey txpoolguy... do you have any info to support that statement? my understanding is that the Leslie's Pool & Spa Lube, a Dupont Krytox product, is virtually inert, and completely safe for all types of elastomers, including the types used in pool equipment o-rings. Have been using it for years, not only on pool o-rings, but on all sorts of other o-rings and gaskets in various plumbing and automotive uses. So far, all those o-rings seem to be holding up extremely well.
#11 quantumchromodynamics
  • Members
  • PipPipPipPipPip
  • 1,469 posts
  • Gender:Male
Posted 25 July 2009 - 11:17 PM
The best lube is Jacks 327 from Hayward.
In my opinion, all o-rings should be lubricated. Lubrication helps the rubber expand and contract smoothly without binding. It allows the force to be equalized throughout the rubber without excessive force focus points. It also helps protect the rubber from decomposition.
Jack's 327 lubricant is the same as Dow Corning's #111 Silicone lubricant.
"Dow Corning® 111 Valve Lubricant and Sealant is a heavy-consistency dimethyl silicone compound that resists a variety of organic and inorganic chemicals.
Dow Corning 111 Valve Lubricant and Sealant can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft vacuum systems, electronic and ignition systems, among others. It can be used as a sealant in applications such as vacuum and pressure systems, equipment subject to washing and harsh environments, electrical service entrances and underground connections, and transformer gaskets and equipment enclosures.
Dow Corning 111 Valve Lubricant and Sealant maintains a serviceable consistency from approximately -70° to 400°F (-57° to 204°C) and has NSF 51, NSF 61 approval and is acceptable as a release agent under FDA 21 CFR 175.300, when used in accordance with that regulation."
https://www.totallyh...Splash_4-62.pdf
You can't manage what you don't measure. Get a good test kit. I recommend the Taylor K-2006 for chlorine or the Taylor K-2106 for bromine.
#12 quantumchromodynamics
  • Members
  • PipPipPipPipPip
  • 1,469 posts
  • Gender:Male
Posted 25 July 2009 - 11:28 PM
http://www.haywardne...v...*&pagenum=2
"What should I use as a lubricant for my o-rings and gaskets?
Hayward recommends a silicone or Teflon based lubricant for all o-rings and gaskets. Jack’s 327, by Hayward, is the best for the job. Other lubricants may cause premature failure and swelling of the o-rings and gaskets. NEVER USE PETROLEUM JELLY for a lubricant. Its’ oils will break down the rubber of the gasket or o-ring."
#13 billp
billp
    Spa Savant
  • Members
  • PipPipPip
  • 81 posts
Posted 09 August 2009 - 07:45 PM
Everyone agrees, NEVER use vaseline or any petroleum product on o-rings. The ones you ask about I think are the o-rings on the unions. I have never found a need to lube these. Beyond that, the more movement the o-ring is subjected to the more it needs lubricant (such as valve shaft o-rings, BW valve o-rings). Magic Lube II is a readily available thick silicone which works well in most circumstances.
Spa savant? Commercial spa, si, portable spa/hot tub, NO!
Fresh water is the cheapest thing you can use in a pool to cure many problems.
