Pool Pump Installation - Concrete Pad
  • Please log in to reply
2 replies to this topic
#1 jafpcu
jafpcu
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 29 May 2009 - 07:32 PM
While replacing my old pump, I noticed it is not bolted down. The concrete pad shows no sign of ever having bolts or anchors. Should I anchor the new pump? (Pentair SuperFlo, 3/4HP.)
Thanks!
#2 Pool Clown
Pool Clown
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 2,719 posts
  • Gender:Male
Posted 29 May 2009 - 09:11 PM
The only need for that is if it is going to be inspected (new pool). I doubt if you pulled a permit to replace a pump. Its to keep the pump from moving in an earthquake, which won't do any good by the way.
Factory Warranty/Service for:
#3 txpoolguy
txpoolguy
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 389 posts
Posted 30 May 2009 - 04:13 AM
Depending on where you live, it's probably not necessary. Bolting the pump down does not allow it to move (float) on the equipment pad as the concrete pad shifts & moves. Unless required by code, it's better not to bolt any of your equipment down. It's easier to service in the future and the bolts usually corrode badly anyway.
