I have a quick question.
I have an Aqua Rite salt generator. A week ago I added salt to the pool to bring the salt level to 3200. the display showed Al - 0. Now the display shows Al - 2. What can I do to change that back to Al - 0. Becasue my instant salinity reading on the display is showing x.xx and not xxxx ppm that I am use to seeing. How can I get that back to the normal xxxx view.
Thanks, any suggestions will do!
AL-0 thru AL-4 are designations for communicating with automation on a pool. You have pushed buttons and flipped the switch enough to put the unit into metric mode. Power down, power up, push the diagnostic button 1 time, switch to superclorinate and back to auto. You should see the salt reading in ppm. :huh:
Thanks, will do!
