Proform Saturn Help - Portable Hot Tubs & Spas - Pool and Spa Forum
(March 25, 2015) POOLSPAFORUM.COM IS INSTALLING A MAJOR SOFTWARE UPGRADE.
EXCITING NEW FEATURES ARE JUST AROUND THE CORNER.
Proform Saturn Help
  • Please log in to reply
6 replies to this topic
#1 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 11 May 2009 - 05:31 PM
I bought a proform saturn by icon fitness back in 04
never really had any problems with it, However I was in the process of cleaning out my porch and rewiring the tub to a gfi and I left the access panel off for a few day in between days off.
Apparently during that time a lovely little rodent moved in. I didnt notice it until I sprang a leak.
The best i can tell one of my leg jets in the recliner is leaking.
I know that where it is because when the water gets below that point it stops. and I can remove the panel there and see the water flowing
Hers the fun
I called proform and the numbers disconnected.
I called icon and they gave me another number to call
I call that number and get a steady busy.
I need to be able to find the parts < tubing/jet > so my pool guy can fix this. he said if I can find the part he can fix it.
Also what do i use to replace the foam that Mickey ripped out into nests.
All around HELP
its a proform saturn
model pfsb62830
#2 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 13 May 2009 - 05:38 AM
come on guys somebody help me out here
#3 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 14 May 2009 - 07:58 PM
http://i183.photobuc...right/jet-2.jpg
http://i183.photobuc...right/jet-1.jpg
here are two pics of the jet i need
#4 ChaiSTi
ChaiSTi
    Spa Savant
  • Members
  • PipPipPip
  • 171 posts
Posted 15 May 2009 - 08:46 AM
This one kinda looks like your.
http://www.spadepot....-P8786C700.aspx
As for the foam, you can fill the missing holes with foam insulation in a can. They can be picked up at Home Depot.
#5 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 18 May 2009 - 07:02 PM
QUOTE (ChaiSTi @ May 15 2009, 11:46 AM) <{POST_SNAPBACK}>
that looks almost exactly like mine.
I have tried to call all around but noone can tell me what type of jet I need.
assuming that this is the right one how do i take it out.
I read to take a flat head screwdriver and pop it under the jet and it should pop off.
I tried that and only successfully ripped the cover and insides out< looked like a small ball with a trumpet>
now i have a small cone inside < i will try to take a pic >
what else will i need o buy to replace it any gaskets or extra pieces? .
I saw a clear gasket type thing that I threw away i assumed it was bad as well.
What do i need to have to hook the new one up can someone help me out here please it desnt look like I will get a pro out here noone will come
#6 vhlittle
vhlittle
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 24 May 2009 - 12:26 PM
I am seeing that you have the exact same spa as me and I was wondering if you found out any info on who to contact about parts? I am looking for the water fall knob for the same spa and am running into the same problem with not having a number to contact for parts or info...I called the customer service number that you did and got the same result of having the number being disconnected...If you have any info for me, I would appreciate it.
QUOTE (mcdlnwright @ May 11 2009, 06:31 PM) <{POST_SNAPBACK}>
Hers the fun
All around HELP
model pfsb62830
#7 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 24 May 2009 - 05:00 PM
they are gone completely, were sold then sold again. the only place that i found any help was www.uspartcenter.com
a gut there named rob was real helpfull
website security
