Help! Heater High Limit Thermostat Tripped On Caldera
  • Please log in to reply
4 replies to this topic
#1 talmaet
talmaet
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 06 February 2009 - 03:49 PM
I have just gotten a used tub = Caldera Kuaui. It showed a flashing "temp" light and then went to The "heater high limit thermostat tripped" symbol within the first hour of running it in new location.
Help??
#2 Dan.The.Spa.Man
Dan.The.Spa.Man
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 699 posts
Posted 06 February 2009 - 04:16 PM
QUOTE (talmaet @ Feb 6 2009, 06:49 PM) <{POST_SNAPBACK}>
Help??
Is there any flow coming out from the circulation pump? It comes out of a small "jet" down near the footwell.
It may have air in the line and if so you would need to bleed it out.
I have a few extra HotSpring heater relay boards for tubs from 2001-2008 if anyone is looking for one cheap. Part #77119
#3 talmaet
talmaet
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 06 February 2009 - 04:46 PM
QUOTE (Dan.The.Spa.Man @ Feb 6 2009, 04:16 PM) <{POST_SNAPBACK}>
Help??
Thanks! I just went back out to check what you wrote. I had turned the circuit breakers off after the total frustration of an afternoon of trying to set it up... So, I turned them back on when I went out. I opened the cover and saw some air bubbles come out of that small jet in the footwell. I hadn't done anything but plug it in. I then turned on the jets and it ran... and a "soft" flow came out of that hole. NO four blinking dashes anymore and it didn't turn itself off. Yeh! But, the temp light is still flashing??
#4 Dan.The.Spa.Man
Dan.The.Spa.Man
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 699 posts
Posted 07 February 2009 - 05:50 AM
QUOTE (talmaet @ Feb 6 2009, 07:46 PM) <{POST_SNAPBACK}>
Help??
Turn the breakers off again for about 20 seconds and turn them back on.
Wait about 1 minute and check to see if the temp light is still flashing. (it may or may not flash for a few seconds before that) As long as the filter is clean and the circ pump is working properly then you will need a new pressure switch if it is still flashing.
#5 ps558
ps558
    Spa Guru
  • Validating
  • PipPipPipPipPip
  • 1,121 posts
Posted 07 February 2009 - 08:00 AM
Help??
Try pulling the filter also to increase circ pump pressure.
