Does Baking Soda Make Water Cloudy?
  • Please log in to reply
3 replies to this topic
#1 r5ran
r5ran
    Spa Savant
  • Members
  • PipPipPip
  • 183 posts
Posted 21 November 2008 - 07:18 AM
Hi, I was wondering if using Arm & Hammer baking soda to raise PH can make your water cloudy? ohmy.gif
I just changed my water a few weeks ago, and it has been absolutely crystal clear till recently. Tuesday night, after soaking, I checked my PH and it was down slightly, so I added a couple tablespoons of baking soda to raise it up (along with the usual MPS and a little hardness increaser). Didn't use the tub Wednesday, but when I went to jump in Thursday night, the water was very cloudy all of a sudden. Could this instant cloudiness be from the baking soda? I searched this forum, and while I found many recommendations to use baking soda instead of spa PH increasers (which everyone says is just sodium bicarbonate, same as baking soda), I found nothing that suggests it can cloud my water. But it just seems like too much coincidence not to be the baking soda....any thoughts or suggestions on this?
Thanks, Randy
#2 Hillbilly Hot Tub
Hillbilly Hot Tub
    Certified Tech
  • Moderators
  • PipPipPipPipPip
  • 1,282 posts
  • Gender:Female
Posted 21 November 2008 - 08:15 AM
QUOTE(r5ran @ Nov 21 2008, 10:18 AM) <{POST_SNAPBACK}>
Thanks, Randy
Baking soda is used to raise the ALK, not PH. It will raise your PH, but slightly. What is your ALK reading now? If it is high it can cause cloudy water. Sodium carbonate (not bi carbonate or hydrogen carbonate) is PH increaser. This is different stuff (arm and hammer super washing soda I think)
Adding it with CH increaser is enhancing the issue. Why did you add CH? Once this is adjusted at a water fill it should not change much unless you are spilling a lot of water out of the tub.
Moderator
Spa and Sauna Sales and Service center
Clearwater and Great Lakes Spas
Helo and Almost Heaven Saunas
Spa Search certified dealer
APSP Member
CPO
#3 tony
tony
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 534 posts
Posted 21 November 2008 - 08:13 PM
High pH can make your water cloudy. Baking soda will raise your pH but only to a max of slightly over 8.0, I believe. What was your pH after adding the baking soda? Cloudy water more often than not signifies a lack of sanitizer.
#4 Nitro
Nitro
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 779 posts
Posted 21 November 2008 - 11:02 PM
If your pH is low, aerate to raise it. Turn on all your jets and air for 30 min. If that doesn't raise your pH, then you can add a little Baking Soda to raise your TA. However, if you don't know your TA, you should be adding anything.
What are your CH, TA and pH levels?
Also, as Tony says you could have low sanitizer levels. What kind of sanitation are you using?
Nitro's Approach To Water Maintenance
A guide to Water Balance and Sanitation using Chlorine
Lowering Total Alkalinity
How to lower TA, without lowering pH
Chlorine Demand (CD)
What is it, and why you should care
Decontamination
How to Super Shock your Tub
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
