Tiny Bubbles From The Hot Water Return - Is This A Problem?
  • Please log in to reply
4 replies to this topic
#1 Paul_SF
Paul_SF
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 29 October 2008 - 04:25 PM
Hi all:
I have a Sundance hot tub. Over the last month, I noticed that the hot water return jet is jetting out a lot of tiny air bubbles. It never used to do that before.
I changed water and the filters today and it still does the same thing.
Do I have a problem? Is it a chemical thing? or do I have a leak? Is air getting into the plumbing/pipes for the water heating system?
Thanks you so much in advance!
Paul
#2 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,136 posts
Posted 30 October 2008 - 01:10 AM
QUOTE(Paul_SF @ Oct 29 2008, 07:25 PM) <{POST_SNAPBACK}>
Hi all:
Paul
Is you tub equipped with an Ozone generator?
Part Time
#3 Paul_SF
Paul_SF
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 30 October 2008 - 03:58 PM
QUOTE(Roger @ Oct 30 2008, 02:10 AM) <{POST_SNAPBACK}>
I don't know. How do I check whether it has an ozone generator?
This is an existing hot tub in a house I bought two years ago. I never noticed the tiny bubbles until when I started about a month ago...
Paul
#4 squidly
squidly
    Spa Savant
  • Members
  • PipPipPip
  • 57 posts
Posted 30 October 2008 - 06:29 PM
Did you hit the tub like the Fonz and say, "aehhhhh"?
That could've triggered something.
#5 tony
tony
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 534 posts
Posted 31 October 2008 - 04:01 AM
QUOTE(squidly @ Oct 30 2008, 10:29 PM) <{POST_SNAPBACK}>
What year is your Sundance? Earlier models that do not have a drain on the floor should have bubbles comming from the return jet if there was ever an ozonator installed. If you didn't have bubbles before and do now, you may have had a bad check valve that has either started working again or the tubing may have come loose. Either way, you should open your equipment bay doors and check to see if you do indeed have an ozonator and that all the tubes are still attached. Ozonators come in all sizes and shapes but there should be 1/4" - 3/8" clear plastic tubing comming from it to an injector in the return plumbing of the spa.
