Salt Water Pools And Itching - All Swimming Pools Types - Pool and Spa Forum
(March 2, 2015) POOLSPAFORUM.COM IS INSTALLING A MAJOR SOFTWARE UPGRADE.
EXCITING NEW FEATURES ARE JUST AROUND THE CORNER.
  • Please log in to reply
3 replies to this topic
#1 twitch
twitch
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 12 October 2008 - 07:50 PM
We just converted our standard chlorine pool over to a saltwater system. We have been in friends pools (more than one) that have the saltwater system and loved it. It felt so clean and didn't have that chlorine smell. We installed ours, our poolman added the salt (as he said does for numerous others in the area) but now not only does our pool still smell like chlorine, our skin itches so much after swimming it makes us crazy. Also, before we added the salt we changed the water since it had been 5 years. Any suggestions? I do trust that our poolman has experience in this but even he is stumped.
Thank you!
#2 jkusmier
jkusmier
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 567 posts
Posted 13 October 2008 - 07:28 PM
QUOTE(twitch @ Oct 12 2008, 10:50 PM) <{POST_SNAPBACK}>
Thank you!
Available or FC, aka free chlorine doesn't cause the chlorine odor you're experiencing - the culprit is combined chlorine or CC, aka combined chlorine. Salt water can sometimes cause a reaction to persons sensitive to it, but that's probably not the cause since multiple persons are complaining of itchy skin after swimming in your pool.
Buy a good test kit and learn to use it - test your FC, CC, pH and TA. I would wager the itchiness is due your pH levels. The chlorine odor can be corrected by shocking the pool to burn out the chloramines. You should also check your salt level, and monitor the output setting on your salt water generator - it may not be set high enough to produce enough chlorine (aim for 3-5ppm FC w/ a salt-water pool). There are tons of fact-filled posts on this forum - use the search engine. Meanwhile, take at least a couple samples to a couple local pool stores and have them test your water. Hint - you should have the samples tested immediately after taking them from the pool - levels, especially FC, can drop quickly and delay will produce inaccurate results.
#3 Strannik
Strannik
    Spa Savant
  • Members
  • PipPipPip
  • 207 posts
Posted 14 October 2008 - 05:48 AM
salt water (in concentrations required for operation of SWG) cannot cause any reactions
it's about the concentration of human tears
so you would be having reaction all the time
other than that - yeah it's chloramines
shock your pool, try to find out what causes the level to rise
TD Consulting - Distributor of AutoChlor Salt Water Chlorine Generators.
Experts in Salt Water Chlorination.
#4 twitch
twitch
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 14 October 2008 - 07:09 AM
QUOTE(jkusmier @ Oct 13 2008, 08:28 PM) <{POST_SNAPBACK}>
Thank you!
Thank you so much, I really appreciate it!!!
website security
