Mixing Chlorine And Bromine - Hot Tub Water Chemistry - Pool and Spa Forum
(March 25, 2015) POOLSPAFORUM.COM IS INSTALLING A MAJOR SOFTWARE UPGRADE.
EXCITING NEW FEATURES ARE JUST AROUND THE CORNER.
  • Please log in to reply
2 replies to this topic
#1 huey graphite
huey graphite
    Junior Member
  • Members
  • PipPip
  • 21 posts
Posted 06 September 2008 - 07:24 AM
I've had a hot tub for the past 8 months and have been using bromine through a floater. How can I shock the tub with Bromine once a week? Or can I shock with liquid chlorine?
I last changed the water 2 months ago and it has a bit of a green hue to it. Also, when the jets are on, there is too much foam and the bubbles are a little dirty. I've rinsed the filter. Any other suggestions? Am I due for another water change?
Thanks in advance.
#2 Hillbilly Hot Tub
Hillbilly Hot Tub
    Certified Tech
  • Moderators
  • PipPipPipPipPip
  • 1,282 posts
  • Gender:Female
Posted 06 September 2008 - 08:44 AM
QUOTE(huey graphite @ Sep 6 2008, 11:24 AM) <{POST_SNAPBACK}>
Thanks in advance.
Water change depends on the size of the tub and its use. Green usually indicates metals in the water that are reacting with the chemicals, unless the tub has no cover and sunshine is creating algea. You can try a metal remover at next fill or get a filling filter to attach to your hose to get these metals out of the water. If its not metals or algea, the other thing I have learned is people that use Irish Spring soap tend to have green foamy water. huh.gif
You shock bromine with chlorine (di-chlor is recommended) or MPS (non-chlorine shock). When you shock the tub it re-establishes the bromine that has been "used up". Tablets that you put in a feeder are usually a bromine/chlorine mix, but shocking is still needed in most cases to super oxidize the water.
Rinsing the filter will help, but have you cleaned it? Foam is from sweat,soap,deaoderant ect that is in the water. Shocking the tub will help this and you can also try a clarifier. Be careful to what kind of clarifer you use, so are oil based and IMO stink. Clean you filters after running a clarifer a day ot 2 later.
Moderator
Spa and Sauna Sales and Service center
Clearwater and Great Lakes Spas
Helo and Almost Heaven Saunas
Spa Search certified dealer
APSP Member
CPO
#3 huey graphite
huey graphite
    Junior Member
  • Members
  • PipPip
  • 21 posts
Posted 08 September 2008 - 10:34 AM
QUOTE(Hillbilly Hot Tub @ Sep 6 2008, 08:44 AM) <{POST_SNAPBACK}>
Thanks in advance.
Great advice.
I have a chemical for soaking the filter in. I will give that a try as well as shocking with a non-chlorine shock.
Thanks
website security
