(May 1, 2013) POOLSPAFORUM.COM SITE UPGRADE!
Members, We are in the beginning stages of a major site upgrade to maximize your online experience.  This includes new content, special reports, mobile connectivity, etc. We've even adding several new layers to protection to help insulate the forum from hackers and spammer attacks that are constantly a challenge.  Thank you and we appreciate your loyalty to the best community on the web!
Starite Sr333na Heater - E01 Error Code
  • Please log in to reply
6 replies to this topic
#1 oc_chuckter
oc_chuckter
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 09 August 2008 - 04:23 PM
Hi,
Turned on my heater for the first time in months today - Service Heater light is on and E01 error code displays. Nothing helpful in the owners manual or on the website, would appreciate some help with troubleshooting this. Thanks!
Chuck
#2 ps558
ps558
    Spa Guru
  • Validating
  • PipPipPipPipPip
  • 1,121 posts
Posted 10 August 2008 - 12:59 PM
QUOTE(oc_chuckter @ Aug 9 2008, 08:23 PM) <{POST_SNAPBACK}>
Hi,
Chuck
I can't find error codes list either. What is the heater doing. Is the blower running? I have replaced the air detection switch in these heaters before.
Other things to check is for any loose wires too
#3 oc_chuckter
oc_chuckter
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 11 August 2008 - 01:12 PM
QUOTE(ps558 @ Aug 10 2008, 01:59 PM) <{POST_SNAPBACK}>
Hi,
Chuck
Thanks for your reply. Nothing is happening with the heater, no blower or other sounds. When turned on the display flashes a few codes (self-diagnostics I assume), then the Service light and error codes appear. Got a service man coming Wed, he didn't seem too worried.
#4 ps558
ps558
    Spa Guru
  • Validating
  • PipPipPipPipPip
  • 1,121 posts
Posted 12 August 2008 - 02:56 AM
QUOTE(oc_chuckter @ Aug 11 2008, 05:12 PM) <{POST_SNAPBACK}>
Hi,
Chuck
Let us know what it was.
#5 oc_chuckter
oc_chuckter
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 15 August 2008 - 02:53 PM
QUOTE(ps558 @ Aug 12 2008, 03:56 AM) <{POST_SNAPBACK}>
Hi,
Chuck
Mystery solved! Some rats (or other small rodent) made a nest inside...and they chewed thru some wires. Cleaned out the leaves & twigs, replaced the wires & all was well!
Thanks all.
#6 tkalla2000
tkalla2000
    Spa Savant
  • Members
  • PipPipPip
  • 50 posts
Posted 16 August 2008 - 01:06 PM
I have seen this happen twice. Both of the heaters had a rat living inside. One of the heaters started acting up, so I I took it apart and cleaned out the nest. The other heater started on fire and almost burned down the guy's garage. I tried putting metal screen in the vents, but the heater was not getting enough air flow. I have told Starite about this issue. Now I take these heaters apart once a month to inspect for debris.
#7 jjoseph1010
jjoseph1010
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 17 July 2009 - 10:57 AM
QUOTE (oc_chuckter @ Aug 15 2008, 06:53 PM) <{POST_SNAPBACK}>
QUOTE (ps558 @ Aug 12 2008, 03:56 AM) <{POST_SNAPBACK}>
QUOTE (oc_chuckter @ Aug 11 2008, 05:12 PM) <{POST_SNAPBACK}>
QUOTE (ps558 @ Aug 10 2008, 01:59 PM) <{POST_SNAPBACK}>
QUOTE (oc_chuckter @ Aug 9 2008, 08:23 PM) <{POST_SNAPBACK}>
Hi,
Chuck
Thanks all.
Chuck nailed it, had same problem E01 real his notes and cleaned out the two nests, repaired the wires, and its working fine now. Saved about $125.00,, Thanks for the help.
Thanks all.
website security
