Turns Green When Adding Shock
#1
Posted 10 June 2008 - 02:48 AM
#2
Posted 10 June 2008 - 05:15 AM
However, you should get your own good test kit (for everything except metals) since pool stores do not always reliably measure the water correctly. See this post for a recent example of three wildly different readings from 3 different pool stores measuring the same pool water. You should get a good test kit, either the Taylor K-2006 you can get at a good online price here or the TF100 kit from tftestkits.com here with the latter kit having 36% more volume of reagents so is comparably priced "per test".
It is hard to know if you still have algae growth or not since you did not post water chemistry numbers, especially Free Chlorine (FC) and Cyanuric Acid (CYA), though pH, Combined Chlorine (CC) and Calcium Hardness (CH) would also be helpful. As far as clearing a pool once the algae is killed and the water is just cloudy, an above ground pool has its own issues due to the lack of a floor drain and poor circulation -- usually a flocculant with vacuum to waste helps as it appeared to in your case, but you may have multiple issues with metal as well (or you could have high CYA and by letting the chlorine level drop the algae may be coming back).
Richard
#3
Posted 10 June 2008 - 09:02 AM
#4
Posted 10 June 2008 - 09:40 AM
That doesn't make any sense. Did you mean that he gave you a copper metal sequestrant or remover? Giving you a copper-based algaecide would just add more copper to the pool and make the problem worse. If he gave you a metal sequestrant, then that can remove the copper and would be the right thing to do if indeed there is copper in the pool (which there most likely is). Of course, that begs the question of where the copper came from in the first place. I'll bet a copper-based algaecide was used at some point. It's good to know how the problem occurred so they can be avoided in the future.
#5
Posted 10 June 2008 - 12:23 PM
I guess it is better to get the information online than in the stores, I don't think they know what they are doing.
#6
Posted 12 June 2008 - 11:16 AM
#7
Posted 13 June 2008 - 09:03 AM
Longer term, water replacement will be needed (you can do partial drain/refill or continuous drain/refill over time) and you'll need to add maintenance doses of Metal Free because it will degrade over time from chlorine. I suspect you got the copper in the pool in the first place from some copper-based algaecide that was used so try and avoid that in the future.
#8
Posted 14 June 2008 - 04:26 AM
Could it be anything else other than metal that turns it green? I have been researching, but don't see any other culprits.
Also, most bottles of chemical don't say what their ingredients are in the product, how would you know what has copper in it or not?
Thanks for your help thus far.
#9
Posted 14 June 2008 - 10:20 AM
I definitely recommend vacuuming to waste. After you've killed the algae present in the water, you surely don't want that waste contaminating your filter. Once you've used a floccing agent like "Super Fallout" that algae will fall out of suspension and be ready to vacuumed to waste. Only way that makes sense to do it.
#10
Posted 14 June 2008 - 01:25 PM
HOWEVER, since your pool isn't holding chlorine, that sounds more like algae -- maybe you've got both a metals problem and algae. For the algae, shock with chlorine and you can lower the pH before you add the chlorine to shock (that will help prevent the metals from turning the pool green and will also help make the chlorine a bit more effective).
You never reported your Cyanuric Acid (CYA) level. If it's really high (> 80) than a partial drain/refill will be needed or you'll have to use something more expensive like a phosphate remover to keep algae from growing. Chlorine alone can prevent and kill algae, but at high CYA levels the level of FC needed becomes impractical.
#11
Posted 14 June 2008 - 04:03 PM
A question, if it was algae, wouldn't the pool be cloudy or have some residue on the vinyl liner or steps?
Looks like tomorrow is the draining day, we are fed up; or we may have to call a pool service for assistance.
HAPPY FATHER'S DAY to all the fathers out there.
#12
Posted 14 June 2008 - 09:24 PM
CYA (Cyanuric Acid) is stabilizer, also called conditioner. So what is that level? Unfortunately, test strips aren't very reliable for that test, but it's better than nothing.
I referred to test kit in this post. If you can't afford those, then Walmart has some inexpensive 5-way or 6-way tests that include CYA. The main downside to the inexpensive tests is that they use a DPD chlorine test that is limited to measuring 5 ppm and bleaches out above 10 ppm. The tests I linked to use a FAS-DPD chlorine test that is accurate to 0.2 ppm and measures up to 50 ppm so is good for measuring chlorine even when shocking.
Richard
#13
Posted 16 June 2008 - 02:52 AM
They told us to shock the pool with a lithium based shock that is suppose to dissolve quicker and work better. We did that last night and the pool looks blue this morning and the chlorine reading was approx a 2 and the Ph was a little high, about a 7.8. Kids went swimming over the weekend, and no one had green hair or any kind of discomfort due to the water, which was a good thing.
#14
Posted 16 June 2008 - 07:00 AM
Coincidence. Lithium hypochlorite is the most expensive form of chlorine, but it is identical in its effects to sodium hypochlorite (chlorinating liquid or unscented bleach) assuming you are adding amounts to produce the same Free Chlorine (FC) level. Because Lithium Hypochlorite is somewhat concentrated (usually around 35% available chlorine), you might have added more to raise the FC higher than you did before or the cumulative chlorine you've been adding finally broke down what was apparently algae.
In any event, I'm glad your pool is now clear. You STILL need to get your CYA level determined because if it's high then the algae can come back if you don't maintain a higher FC level. Do you know how much Lithium Hypochlorite powder you added in your 15,000 gallon pool? One pound of Lithium Hypochlorite in your sized pool would raise the FC by 2.8 ppm.
Richard
#15
Posted 23 June 2008 - 03:47 AM
We treated the pool with PhosFree by Natural Chemistry because the pool store mentioned our level may be high. I purchased a Phosphate test kit and it read high (close to 1000ppb). After following instructions, retested recently and it was showing approx 300ppb. I did read about phosphates and it said that it could cause the chlorine problem. I am not sure if it is working though.
I also noticed that the water has a mildewy smell to it. Sounds funny, but the towels and bathing suits have a mildewy smell.
I hope we can get this figured out before the end of the summer. I feel like a chemist when I go out everyday with all these test kits.
#16
Posted 23 June 2008 - 03:50 AM
