Infinity Sun Peak Spa - I Have No Manual So Need Help To Get My Spa To Heat
  • Please log in to reply
5 replies to this topic
#1 kellibarr
kellibarr
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 13 May 2008 - 04:04 PM
Hi everyone. I received my hottub the other day, from costco. The hottub seems real nice but it came with nothing, missing the manual, filter cartridge, filter lid, head cushions, etc. So I am wondering why it keep going back to the SL mode and it won't heat past 87 degrees. I have pushed all the different buttons and have the heat set to 104 but it won't heat that high, also I see there are modes like F2, F4, F6, F8 but it always goes back to SL and the heat is never on. How do I get it to work properly or is there a problem within the spa? I would appreciate any help out there!! It is waiting to be used but it is just not heating properly.
#2 sandi
sandi
    Spa Savant
  • Members
  • PipPipPip
  • 182 posts
Posted 13 May 2008 - 05:04 PM
QUOTE(kellibarr @ May 13 2008, 04:04 PM) <{POST_SNAPBACK}>
The tub has 3 modes:
EC = economy - water only heats during filter cycles
SL = sleep - keeps low heat for freeze protection
ST = standard - keeps full temp at all times
To change between the 3 modes, press the temp button and then the light button.
Filtration cycles - the spa filters every 12 hours
F2 - F8 - how many hours the spa filters per cycle (ie. F2 = spa filters for 2 hours every 12 hours)
To change filtration cycles, press the temp button then the jets button closest to the display screen.
Hope this helps. Also hope that Infinity is responsive about getting you the things that didn't show up with the spa. Not a great way to start out! Good luck.
Sandi
#3 kengorman
kengorman
    Spa Savant
  • Members
  • PipPipPip
  • 219 posts
Posted 13 May 2008 - 07:00 PM
QUOTE(kellibarr @ May 13 2008, 08:04 PM) <{POST_SNAPBACK}>
The Infinity Sun Peak uses a Balboa M-7 SUV pack and a quick reference guide can be found at the link here.
Also, the owner's manual can be found on Infinity's web-site here
In SL mode, it will only heat the spa to within 20 degrees of the set temperature during filtration cycles.
To heat your spa up, I'd first recommend changing to Standard mode as per Sandi's instructions in the previous post. With the cover on, the spa should heat up about 7 degrees per hour.
Good luck with your spa.
Ken
#4 Roger
Roger
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 4,136 posts
Posted 14 May 2008 - 12:55 AM
Do NOT use the spa without a filter.
Part Time
#5 mrutkaus
mrutkaus
    Junior Member
  • Members
  • PipPip
  • 11 posts
Posted 14 May 2008 - 02:35 AM
As it no doubt says in your manual linked above, after you select the mode you want you may have to confirm it by pressing a pump button. I have to do that with the Balboa VS system in my new Costco 3 person spa.
Mike
#6 Biz
Biz
    Spa Savant
  • Members
  • PipPipPip
  • 89 posts
Posted 14 May 2008 - 04:44 AM
Just curious, our Sun Peak is scheduled to be delivered Thursday around 7:00PM. Did you ask the drivers to place your hot tub where you wanted it or did they just drop it at curbside? If they moved it for you, how much did you pay them?
Thanks
