Rattle In The Pump - Portable Hot Tubs & Spas - Pool and Spa Forum
(January 9, 2015) POOLSPAFORUM.COM SITE UPGRADE!
Rattle In The Pump
  • Please log in to reply
10 replies to this topic
#1 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 19 February 2008 - 08:45 AM
If you read my other topic you will already know about My baking soda nightmare.
After recovering from that I drained, scrubbed and refilled. When it was refilled we stuck the hose in the filter intake < basically to hold it still >
it filled and heated without a issue. But when we ran it we heard a large rattle in the pump area. The only thing I can think of is possibly the rubber gasket in the water hose came off and ended up in the pump intake area.
I went to look at the pump today and saw two different valves one of the left and one on the right. I am assuming that is the intake and output.
Directly in front of the pump is a silver control box?
and the pump has a large silver tube connected to one end.
It seems to be plumbed with 2" pvc. But I don't see how to disconnect it.
And when I tried to turn the fittings connecting it the wouldn't budge. And I didn't want to put too much pressure in case i was wrong
Any help would be great
#2 Chas
Chas
    Nice guy. Really.
  • Moderators
  • PipPipPipPipPip
  • 1,334 posts
Posted 19 February 2008 - 10:11 AM
You may be able to suck the item outof the pump by back-flowing it. Turn off power to the spa. Then beg, borrow or buy a pool vac hose. Start a siphon, and be sure it is going real well. While it is pulling hard, stick the hose over the openning where you put the garden hose. Remove any standpipes, screens, or other things which would keep the suction from working directly on the inlet to the pump in question.
Try this a few times, and be sure to put the filter back in before you run the pump to see if it still rattles.
If this doesn't work you will have to open the pump and see if you can clear it.
HTH
Poolspaforum.com Moderator
Award Winning HotSpring Dealer
#3 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 20 February 2008 - 07:29 AM
QUOTE(Chas @ Feb 19 2008, 12:11 PM) <{POST_SNAPBACK}>
HTH
but how do i get into it?
it seems to be all hard plumbed and i dont see any unions to take it apart
#4 spatech (the unreal one)
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 3,818 posts
Posted 20 February 2008 - 08:08 AM
QUOTE(mcdlnwright @ Feb 20 2008, 07:29 AM) <{POST_SNAPBACK}>
HTH
Chas' point is to try to suck it back OUT so that you donít even have to get into it. That would be the first course of action.
#5 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 20 February 2008 - 08:10 AM
QUOTE(spatech (the unreal one) @ Feb 20 2008, 10:08 AM) <{POST_SNAPBACK}>
Chas' point is to try to suck it back OUT so that you don’t even have to get into it. That would be the first course of action.
i realize that but i dont have a pump to do that.
#6 spatech (the unreal one)
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 3,818 posts
Posted 20 February 2008 - 08:20 AM
QUOTE(mcdlnwright @ Feb 20 2008, 08:10 AM) <{POST_SNAPBACK}>
Read his suggestion, though a pump would be great there was no mention of using a pump. You start a siphon in the main part of the spa and once its going good you move the hose to the filter opening where you think you lost something and stick the hose in that hole. Hopefully it will suck the piece back out.
#7 Chas
Chas
    Nice guy. Really.
  • Moderators
  • PipPipPipPipPip
  • 1,334 posts
Posted 20 February 2008 - 08:23 AM
I never said anything about a pump. Siphon the water - you will be amazed at the suction power this can create.
A pool vac hose - begged, borrowed or bought - will be far less than a service call, and you can use it later for water changes.
Win win.
#8 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 20 February 2008 - 08:47 AM
QUOTE(Chas @ Feb 20 2008, 10:23 AM) <{POST_SNAPBACK}>
Win win.
I have one of those
But heres the um other issue,
I hard plumbed my pool last year because the hose that came with it kept bubbling. it was clear with a wire running around it.
Well my son ran into it and broke the threaded end of the male adapter in the diaphragm. now i have no idea how to get that out
#9 Chas
Chas
    Nice guy. Really.
  • Moderators
  • PipPipPipPipPip
  • 1,334 posts
Posted 20 February 2008 - 10:08 AM
Call a tech.
#10 mcdlnwright
mcdlnwright
    Junior Member
  • Members
  • PipPip
  • 17 posts
Posted 21 February 2008 - 07:54 AM
I had though that if i used a 2x2 shaved into a slight spike i could wedge it into the inside of the male adapter and turn it out?
sort of like the do to those screws that are stripped out
#11 spatech (the unreal one)
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 3,818 posts
Posted 21 February 2008 - 08:36 AM
QUOTE(mcdlnwright @ Feb 21 2008, 07:54 AM) <{POST_SNAPBACK}>
Sounds like a plan; let us know how it works.
website security
